MK5 Crankshaft Pulley for two belts
Postby Peterr » Fri Jul 25, 2025 4:53 am
Crankshaft Pulley for two belts, “V” and “Grooved” for AC
Keep on Transiting !
Peterr
Re: MK5 Crankshaft Pulley for two belts
Postby MinorMatt » Tue Jul 29, 2025 1:11 pm
Thats not an AC pulley - its a non AC one. The power steering is driven off the front Vee.
Aircon ones have 2 plates for multi vee belts - the AC belt is a 6pk one
Postby Peterr » Tue Jul 29, 2025 2:13 pm
The AC compressor doesn’t have a V belt
Peterr
Postby Peterr » Tue Jul 29, 2025 2:15 pm
See photo
Peterr
Postby Peterr » Tue Jul 29, 2025 3:07 pm
I believe there are two versions.
Peterr
Postby Peterr » Tue Jul 29, 2025 3:12 pm
This uses two V belts
Peterr
Postby Peterr » Wed Jul 30, 2025 7:33 am
My MK5 looks like this and I want to mount the compressor. I have the proper bracket. Just need to figure out how to add the belt. I intend to use the compressor to fill a rear mounted air tank to about 8 bar for painting. This has been done before with the same compressor and works great.
Peterr
Postby MinorMatt » Wed Jul 30, 2025 1:16 pm
Peterr wrote:See photo
Yes you can see the 6PK belt drive on those. No V belts
Postby MinorMatt » Wed Jul 30, 2025 1:17 pm
Peterr wrote:This uses two V belts
Thats an aftermarket PTO rather than aircon. Common for ice cream vans with soft serve. There is a shaft that come out and drives the machine in the cab
Postby Peterr » Wed Jul 30, 2025 4:21 pm
PTO means? 6PK means?
Peterr
Postby MinorMatt » Mon Aug 04, 2025 10:04 am
PTO is power take off - typically engine driven with an electric clutch to drive a shaft or hydraulic pump.
6pk means a poly Vee belt (the flat type with lots of grooves) - with 6 grooves. The other one is a 4PK - 4 grooves
Postby Peterr » Mon Aug 04, 2025 10:55 am
Thanks! I need to figure out how to attach the compressor and add the correct pulley. I already have power steering. The options are to change the crankshaft pulley (only V belts) or change the compressor pulley (which currently has a 6 grooved belt) to a V belt which may be the easiest option.
Peterr
Postby MinorMatt » Mon Aug 04, 2025 11:16 am
Im sure I will have a crankshaft pully with the inner 4 groove belt and the single V on the outside.
I got rid of the ones with the 6 groove when I sold all my aircon stuff
Postby Peterr » Mon Aug 04, 2025 11:27 am
The compressor has 6 grooves. Don’t know if it can run with a 4 groove belt. Wouldn’t be critical since the compressor is only occasionally running. (Photo is of another engine where I removed the compressor)
Peterr
Postby MinorMatt » Mon Aug 04, 2025 12:08 pm
Ok,
So you need the type with the 4 groove belt (alternator, water pump etc) and a 6 groove for the AC Compressor... (not the type shown in your pic).
It appears you are looking for part no 1042771 or 1050620
I've looked and I can't find one at any of my normal sources :(
