Fuse 72 blowing mk7
Fuse 72 blowing mk7
Postby avromo » Wed Aug 06, 2025 1:00 am
Hi my radio is currently not working
When I change fuse 72 it keeps on blowing
I am trying to trace this
I noticed that it says that this fuse also powers "phone supply" anyone know what this is referring to?
Mk7 2009 T370 140 2.4 rwd
avromo
Re: Fuse 72 blowing mk7
Postby DanMK7uk » Wed Aug 06, 2025 1:41 am
Disconnect interior lights and plug in one by one check the obd socket to
DanMK7uk
Postby avromo » Wed Aug 06, 2025 2:30 pm
I actually removed all interior bulbs intending to replace with led but have not yet. I was wandering if that was the cause but are they not on a different fuse?
avromo
Postby DanMK7uk » Wed Aug 06, 2025 5:34 pm
avromo wrote:I actually removed all interior bulbs intending to replace with led but have not yet. I was wandering if that was the cause but are they not on a different fuse?
Nope. Fuse 72. If the issue started around that time. Suspect the lights.
DanMK7uk
Postby avromo » Wed Aug 06, 2025 6:57 pm
Sorry just checked it was 73 that was blowing, apologies
avromo
Postby DanMK7uk » Wed Aug 06, 2025 7:15 pm
https://www.startmycar.com/gb/ford/tran ... ms-article
If you scroll to the top to, it show 82 linked
DanMK7uk
Postby avromo » Wed Aug 06, 2025 7:38 pm
DanMK7uk wrote:https://www.startmycar.com/gb/ford/transit/info/fusebox/2006/restyle-restyle/radio-fuse#problems-article
I see that but I don't understand your intention?
avromo
Postby DanMK7uk » Wed Aug 06, 2025 8:43 pm
Raaaa ? Check 82 too. Disconnect radio for a kick off see if still pops fuse. Check all wiring and connections
DanMK7uk
Postby avromo » Wed Aug 06, 2025 11:09 pm
Ok thanks
avromo
Postby avromo » Thu Aug 07, 2025 11:58 am
Managed to get the radio out (why do they make it so annoying and why did my trim kit only come with 2 keys aaargh and are they made to cut fingers??!!)
No longer blowing the fuse so I assume it's a prob with the radio itself?
I had an old pioneer but the loom is different what should I be looking for to replace with?
avromo
Postby T350camper » Thu Aug 07, 2025 12:37 pm
Maybe an ISO converter loom like this to use your Pioneer?
https://www.ebay.co.uk/itm/364607540813 ... R8aMjcWQZg
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Postby avromo » Thu Aug 07, 2025 1:02 pm
Looks good, thanks
avromo
Postby avromo » Fri Aug 08, 2025 2:21 pm
Just got a loom off Amazon and plugged in an old stereo I had to test and it works no more fuse 72 blowing. So for ppl that have this issue it turns out a faulty head unit can cause the fuse to blow, quite an easy thing to rule out before checking all wiring
avromo
Postby DanMK7uk » Fri Aug 08, 2025 6:39 pm
Excellent
DanMK7uk
Postby avromo » Sun Aug 10, 2025 8:57 pm
I am noticing that the stereo seems to reset each time I turn off the engine, is the loom I bought missing a trick?
avromo
