Yz Garry wrote:Can I ask why if it’s left over night and I go out to it in the morning it will start up spot on 1st time
Yz Garry wrote:Little update I got the van plugged in today to forscan and only code I am getting is p0340 cam sensor and my fuel rail pressure is over 3000 on start up and I was able to do lean test and I also fitted new leak off seals today and going pick new cam sensor up tomorrow.
DanMK7uk wrote:Leak off does he mean ?
Yz Garry wrote:I would not say empty I would say around half
Yz Garry wrote:I have changed leak off seals checked fuel filter housing for cracks can’t see any checked all fuel lines round engine can’t see anything losing the will to live now.
Yz Garry wrote:ok I will check everything again tomorrow and see if I can come cross anything thank you
Kopon wrote:Yz Garry wrote:ok I will check everything again tomorrow and see if I can come cross anything thank you
So how did you get on?
I have a similar query with mine but my hot start problem happens even if I've only just swithed the engine off so there wouldn't be time for the filter to lose fuel.
How soon after stopping your engine did you find the filter to be half full?
Thanks.
Users browsing this forum: knobby1
