What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby ned » Tue Jul 15, 2025 11:51 am
Mot failed, no too bad for an 18 year old van
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby ned » Tue Jul 15, 2025 1:14 pm
Can’t see why the drop link was faulty, nice shiny parts for about a week, just the bloody handbrake to do now
ned
Postby loot » Fri Jul 18, 2025 10:48 pm
ned wrote:Can’t see why the drop link was faulty, nice shiny parts for about a week, just the bloody handbrake to do now
Mine was similar :P
Tap I tap i tap.
07 350 170ps
Ids map here
loot
Postby Redvee » Fri Jul 18, 2025 11:28 pm
Finished stripping the campervan conversion out of the van in readiness for the welding next week. With the camper buts out I can see the ventilation around the wheelarches which is why the yellow crayon was used in excess on the MOT. When I rebuild the van I'll be adding soundproof and insulation as thete was none when the previous owner had it converted. I've got till late October to get it rebuilt in readiness for the honeymoon.
Redvee
Postby Redvee » Thu Aug 14, 2025 10:45 pm
Phonecall from the MOT garage this morning, the van passed the MOT and all the yellow crayon on the chassis has been dealt with along with new pads, a wheel bearing and track rod ends on the front axle. Apart from an advisory about a frayed seatbelt Bessie is good to go.
I now have the job of rebuilding the interior but having an operation on Monday means I'm off sick but unable to do anything heavy till next week, OHs orders. She's allowed me to do little minor jobs like cleaning the interior etc.
Redvee
Postby Galway » Wed Aug 20, 2025 12:42 am
Today I rigged up a 12vdc to 24vdc converter to allow me run my CPAP machine.
Went for a more premium converter and analysed 24vdc as a previous cheapy one showed voltage spikes on energising, so didn't want to risk frying expensive CPAP.
2010 Mk7 fwd 140hp T350 Camper
Galway
Postby Harvy » Wed Aug 20, 2025 8:43 am
I fitted a boost gauge! :lol: :mrgreen: I bought an eBay special and have fitted it to the dashboard on the passenger side (the vacuum hose was not long enough to fit on the drivers side). I’ve let my inner chav come out because it will be interesting to keep an eye on my turbo. Plus if it’s good enough for Lord Knobrot….. :mrgreen:
2010 T350 LWB H3 RWD 2.4 115 Full poverty spec! :D
Harvy
Postby ned » Wed Aug 20, 2025 12:35 pm
Harvy wrote:I fitted a boost gauge! :lol: :mrgreen: I bought an eBay special and have fitted it to the dashboard on the passenger side (the vacuum hose was not long enough to fit on the drivers side). I’ve let my inner chav come out because it will be interesting to keep an eye on my turbo. Plus if it’s good enough for Lord Knobrot….. :mrgreen:
Nowt wrong with have a boost gauge,
Washer jet hose works to extend the pipe
ned
Postby ned » Wed Aug 20, 2025 12:36 pm
Mine was similar :P
Tap I tap i tap.
Tapi tapi tapi, I somehow missed this, I was toying with the idea of air shocks for the rear (not air bags) is the spring brakes as well
ned
Postby Altransit » Wed Aug 20, 2025 1:42 pm
Eldest son fitted one in the A pillar trim in his Focus TDDi, I never worked out what its purpose was :P :lol:
I'm more of a Voltmeter/Ammeter, oil pressure gauge kind of guy :roll:
Postby Burn2 » Wed Aug 20, 2025 2:45 pm
As you are talking about gauge, do you know if the ScanGauge II works well on the transit 2.4 tdci?
Burn2
Postby ned » Wed Aug 20, 2025 5:36 pm
Aye the boost gauge saved lucifers engine from running away, noticed I had no boost stopped the van to find the turbine part of the turbo had snapped off, the oil pressure gauge is more important I think
ned
Postby ned » Mon Aug 25, 2025 1:40 pm
Did a little bit more of the stretchy carpet stuff, need to order more for the drivers door and get some matt black plastic paint for the door grab/window switch and door handle
ned
Postby Harvy » Mon Aug 25, 2025 7:46 pm
ned wrote:Did a little bit more of the stretchy carpet stuff, need to order more for the drivers door and get some matt black plastic paint for the door grab/window switch and door handle
That looks very nice! Which stuff did you buy. I want to get some and have been told you get what you pay for. YouTube recommended Harrison trim supplies. They could have been sponsored though… :lol:
Harvy
Postby ned » Tue Aug 26, 2025 6:08 am
I used this stuff off eBay, 3x2m was £20 it’s seems ok for the price baring in mind my vans a work van so probably going to get paint or something on it so didn’t want to spend a fortune
ned
