Lyntransit wrote:Hi thanks for advice. I only changed the batteries so wires ok.on the leisure battery there's only two wires negative a d 1 positive going into loom. When I'm on hookup and zig set to charge leisure battery is charging. It's a old van but if I got a relay kit off Ebay would that solve it ?cheers
Lyntransit wrote:Hi i am assuming that the only red wire on leisure battery is to the zig unit .I don't know where the relay is if it has one all the fuses don't list a fuse or relay that's why I thought a cheap ebay split charge relay kit might do the job. Cheers
Lyntransit wrote:Hi thanks for the info. I will check fuse box for split charge stuff. That voltro ice sounds good will a solar panel also charge leisure battery aswell. Cheers
Lyntransit wrote:Hi I've found the relay its a durite p234-26 or 28 its hard to make out. Anyway it as 4 wires fitted i will try and trace were they all go on I'm trying to see if it as fuse between relay and leisure battery but haven't found that yet. Cheers
