ericjmoran2003 wrote:Hey all, seems like this is a common issue on the 2010 MK6, so hopefully somebody can help here. When I unlock my sliding door, I hear the actual sound, but the lock doesn't disengage. If I lean against the door, then it works. I'm assuming this means contact with the plate is bad? Is there an easy way to adjust one of the plates?
knobby1 wrote:ericjmoran2003 wrote:Hey all, seems like this is a common issue on the 2010 MK6, so hopefully somebody can help here. When I unlock my sliding door, I hear the actual sound, but the lock doesn't disengage. If I lean against the door, then it works. I'm assuming this means contact with the plate is bad? Is there an easy way to adjust one of the plates?
Is there a way to manually unlock it from the inside? The most annoying thing is that even the interior handle for the sliding door doesn't engage, and when the "leaning" method doesn't work, I'm left just using the remote until somehow it finally unlocks. I'm tempted to just disconnect the lock on that door now
Yeah...very common...leaning on the rear of the door unloads the lock mechanism...allowing it to unlatch...Possibly the rollers are worn or misaligned, door dropped a bit, or the mechanism itself is getting tired, they don't last forever. The rollers supporting the door are "adjustable" too.
ericjmoran2003 wrote:Is there a way to manually unlock it from the inside? The most annoying thing is that even the interior handle for the sliding door doesn't engage, and when the "leaning" method doesn't work, I'm left just using the remote until somehow it finally unlocks. I'm tempted to just disconnect the lock on that door now
Altransit wrote:mine has been doing this for years now, and I'm too lazy to try and fix it, but it never fails to unlock if I lean on the lower rear of the door whilst pressing the remote unlock button.
knobby1 wrote:Altransit wrote:mine has been doing this for years now, and I'm too lazy to try and fix it, but it never fails to unlock if I lean on the lower rear of the door whilst pressing the remote unlock button.
Likewise for me...mine has been like it since I bought the van in 2014..!
Altransit wrote:knobby1 wrote:Altransit wrote:mine has been doing this for years now, and I'm too lazy to try and fix it, but it never fails to unlock if I lean on the lower rear of the door whilst pressing the remote unlock button.
If mine fails to unlock, because I forgot to press in the lower rear, (or the grandkids did it and didn't press hard enough) you have to re-lock the van and try again, pressing the unlock a second time doesn't do it, for some reason![]()
.....but when its changed its heaven
