Ford Transit 2.4 D0FA tddi Engine doesn’t start
Postby Weinigstress » Sun Sep 14, 2025 11:46 am
Hello all,
After my last post I have rebuild my Ford Transit 2.4 D0FA tddi engine. In short:
New cylinder head and new injectors, chain etc. I did not replace the fuel pump.
Im trying to start the engine but the engine only fires shortly, please view my added video:
https://youtu.be/OpJBN9EyhHw?si=xMWMBIIgaVLOnJ1G
Thing to mention. I replaced the fuel filter, but it did not seem to fit perfectly, so potentially some air coming in the system? I went for a cheaper one/other brand, but it did not fit perfect. I already ordered the same one as the removed one. To be continued. However i don’t believe this is the real problem.
I am tending to think is has something to do with the fuel pump starting solenoid. The reason is because I noticed when starting quickly after each attempt it wanted to start, when it actually starts it drops when i stop turning the key to start. It only tends to run when key remains in the starter position. It stops running instantly after i stop starting.
Looking at the video and hearing / seeing my problem what do you think is the issue and what would you suggest me doing next?
Thanks for your help, much appreciated!!
Weinigstress
Re: Ford Transit 2.4 D0FA tddi Engine doesn’t start
Postby metalworker0 » Sun Sep 14, 2025 2:54 pm
Well being a tddi says to me it could have problem with the edu/ edc unit on top of the pump , this is a common fail on the tddi's .. but you must have a code reader to read the codes that point it out, here they recommend forscan .
Forscan
if you have forscan you would have more info than just fault codes.
as regards reading codes
NOTE: you can use forscan to get correct fault codes with proper DETAILED explanation of them - a generic fault code reader may be somewhat misleading, or doesn't work (or we on the forum are unfamiliar with it)_you can see a lot more with forscan. like live running data etc of all systems, everything .. ABS signals, EGR open percentages, pressures, temperatures , graphs
"Forscan" is FREE software that you download to a laptop..you buy the interface cable -- this is just the cable, you need a laptop)
You can join the forscan forum ..again free, to get the software and more answers.
https://forscan.org/forum/
Postby knobby1 » Sun Sep 14, 2025 8:08 pm
Please don't run two different threads on the same issue...it confuses all the old farts...and you'll get multiple different answers to the same question.
viewtopic.php?f=5&t=235058
Postby Weinigstress » Sun Sep 14, 2025 9:18 pm
knobby1 wrote:Please don't run two different threads on the same issue...it confuses all the old farts...and you'll get multiple different answers to the same question.
Got some issues with uploading my question. If want you can delete it. Thanks for helping out!
Weinigstress
Postby knobby1 » Sun Sep 14, 2025 11:34 pm
Unfortunately, I'm not one of the admins.
