The pictures say it all below, rear door cable ducts have had it! How is this fixed?
metalworker0 wrote:i had a look on catcar.info .. the drawings there .. don't look anything like yours
1418425 and 1418424 ford - here
http://www.catcar.info/ford/?lang=en&l= ... OCsxMzU%3D
had a look at ebay to see actual pictures, not drawings.. nothing comes up.
this stuff would be way better .. using google .. and the words --- as link too long to work here .
type in
articulated chain cable armour
Thanks but not sure you understand what I mean. This thing is full of wires, no idea how the chain type thing could help, maybe me being dumb but didn't follow sorry
for something that looks like so
https://m.media-amazon.com/images/I/612 ... SL500_.jpg
. but needs to be investigated, if it will fit in the door gap when closed
also you could try lay flat garden hose pipe
https://m.media-amazon.com/images/I/31t ... L._AC_.jpg
tranmx2 wrote:2012 Mk7.
LHS.
Has coloured wires to the upper brake light and number plate.
The tubes move about 6 inches within the door.
One tube has about 4 coloured wires in it the other tube is the carrier tube which may be solid.
Likely it'll be easier to cut the wires in the door and pillar then remove the tubes with the cut off wires within.
To access inside the pillar the light cluster shall need to be removed.
Connect the wires re' colours to your replacement wires which'll be within your replacement tube.
That tube may need to be fixed to the pillar.
Rhs.
Has all black wires to the lock.
You'll need to make sure you dont' get them mixed up.
If cutting the wires etc is daunting then likely the whole harness can be purchased and fitted.
tranmx2 wrote:2006 to 2013 transit.
They aint all the same!
£185 Left side https://www.transitcenter.uk/rear-door- ... vH5FEMizP5
£199.50 right side https://www.transitcenter.uk/rear-right ... sTyFBg0v2r
