loot wrote:Ids says try 3 times but also says that doing the learns might not be necessary and they question the validity of the tests
I don't that they can be either dead easy to go through both learns or a nightmare.
loot wrote:I've found that programmed or unprogrammed injectors never made that much of a difference in power. A slight smoothness in tickover and less chatter was noticed. But I wouldn't rely on seeing massive power gains. If you feel the van is just not pulling like it should then maybe it's another issue. Get on live data and check map results etc.
loot wrote:Jesus you don't mind driving do you Matt
