2.0 euro6 gearing verses 2.2 euro5
Postby aln101tf » Thu Oct 02, 2025 12:02 am
Hello all,
Reluctantly about to replace my 2013 Tourneo with the more recent model, adblue, wet belts, etc !*?*! Probably about 2020 ish.
My 2.2 had really long gearing (which I changed) and I'm wondering whether the 2.0 euro6 has the same ridiculous gearing, or did Ford fix this?
Searched, but only found one comment that it was pretty long.
thanks, Alan
Mk6 125/330 swb lr rwd 2.4L remapped.
Mk7 115/330 swb lr rwd 2.4L remapped.
Custom Tourneo swb 125ps 2.2L remapped to 170ps and final drive gearing lowered 12% to T340.
Custom Tourneo L2 Auto 130ps 2.0L Forscan remapped to ford 170ps
aln101tf
Re: 2.0 euro6 gearing verses 2.2 euro5
Postby metalworker0 » Thu Oct 02, 2025 5:58 pm
this is what Ford says about the ratios of an ecoblue custom transit .. i don't know your ratios .. but you do .. so .. you'll have to compare
FROM HERE - noting this is 2024 spec.
https://media.ford.com/content/dam/ford ... 024_EU.pdf
EcoBlue eight-speed auto
Gear ratio
8th - 0.616
7th - 0.742
6th - 1
5th -1.414
4th- 1.842
3rd - 2.872
2nd -3.146
1st - 4.484
Reverse - -2.882
Final drive 3.650:1
EcoBlue six-speed manual
Gear ratio
6th - 0.683
5th - 0.780
4th - 0.844
3rd - 1.121
2nd - 1.952
1st - 3.727
Reverse -1.423
Final drive - 4.930:1
Postby aln101tf » Thu Oct 02, 2025 7:29 pm
Thanks for that.
Can't remember my own ratios now. Over sixties syndrome !
I was really looking for someone to post their revs verses speed in top.
Just drove a friends 2.0 auto today, and I only counted six gears. It was at about 1800 revs at 60, which was a nice surprise. At least Ford got that right.
Alan
aln101tf
Postby aln101tf » Tue Oct 07, 2025 9:18 pm
Oh well...
I guess no-one looks at their rev counters these days.
aln101tf
Postby metalworker0 » Tue Oct 07, 2025 10:11 pm
110 views says they are too idle to answer
Postby Altransit » Wed Oct 08, 2025 9:46 am
metalworker0 wrote:110 views says they are too idle to answer
............ or maybe 110 views by people who like reading posts for the information, but don't have the same setup, in order to give a useful answer :idea:
My Euro 4 5 speed Mk7 does 26mph per 1000 revs in top gear, but that information is of no use to the OP :|
Postby mompracen_bs » Wed Oct 08, 2025 1:06 pm
metalworker0 wrote:this is what Ford says about the ratios of an ecoblue custom transit .. i don't know your ratios .. but you do .. so .. you'll have to compare
Gear ratio (speed at 1800 RPM)
8th - 0.616 (64 MPH)
7th - 0.742 (53 MPH)
6th - 1 (40 MPH)
5th -1.414 (28 MPH)
4th- 1.842 (21.5 MPH)
3rd - 2.872 (13.8 MPH)
2nd -3.146 (12.6 MPH)
1st - 4.484 (9 MPH)
Reverse - -2.882
Final drive 3.650:1
6th - 0.683 (42.94 MPH)
5th - 0.780 (37.6 MPH)
4th - 0.844 (34.75 MPH)
3rd - 1.121 (26.16 MPH)
2nd - 1.952 (15 MPH)
1st - 3.727 (7.9 MPH)
Reverse -1.423
tyre 215/65-16 external diameter 27"
con i configuratori online è possibile fare dei confronti
https://tremec.com/aftermarket/resource ... alculator/
mompracen_bs
Postby aln101tf » Fri Oct 10, 2025 9:18 am
Those manual ratios / speeds don't look right. 43mph at 1800 rpm in 6th ??? How did you calculate those ?
Just had a short spin in a ecoblue custom van last night. It was on 1500 revs at 60 which is pretty similar to my early custom.
It wasn't really interested below 1500 either which also sounds familiar. Damn!
aln101tf
Postby metalworker0 » Fri Oct 10, 2025 11:49 am
who's that answer for ?
Postby 2tall » Sat Oct 11, 2025 12:06 pm
Here's the gearing for Euro6 with different FD options:
And here's the same for Euro5:
And here are the revs @ 100 km/h in 6th gear with 235/65R16 tyres on a 2022 Custom 300:
2tall
Postby mompracen_bs » Mon Oct 13, 2025 11:16 am
2tall wrote:Here's the gearing for Euro6 with different FD options:
I tried various online calculators and the table shown above.
But they all indicate that to reach 100km/h, the engine should be at about 2100 rpm (not 1800 rpm as shown in the photo).
2022 Custom 300 (Euro 6)
235/65R16 (= outer diameter 28"/711mm)
6th 0.683
final drive 4.19
2100 rpm
=98 km/h/61 mph
Am I doing something wrong?
EDIT
Sorry, I made a mistake!
The following are correct: 3 manual transmission options available for Euro6 engine (2.0 ECOBLUE) + 6th gear + 235/65R16
Final Drive 4.19 → ≈ 1,552 RPM
Final Drive 4.43 → ≈ 1,663 RPM
Final Drive 4.93 → ≈ 1,760 RPM (I believe this is the case shown in the photo)
Last edited by mompracen_bs on Mon Oct 13, 2025 11:57 am, edited 2 times in total.
mompracen_bs
Postby 2tall » Mon Oct 13, 2025 11:49 am
mompracen_bs wrote:I tried various online calculators and the table shown above.
6th 0.683
final drive 4.19
2100 rpm
=98 km/h/61 mph
You're right, something doesn't add up with the ratios.
The ratios are from BEMM. Tried different calculations and they don't correlate with the actual rpms of my Custom. Oh well :o
2tall
Postby mompracen_bs » Mon Oct 13, 2025 11:55 am
6th 0.683
final drive 4.19
2100 rpm
=98 km/h/61 mph
I edited the message, now it's correct, I hope!
P.S.
BEMM magic document!
mompracen_bs
Postby mompracen_bs » Mon Oct 13, 2025 1:36 pm
Is 4th gear shorter than 5th gear?
3th 1.121
4th 0.780
5th 0.844
6th 0.683
mompracen_bs
Postby mompracen_bs » Tue Oct 14, 2025 9:00 am
Gear ratio
8th - 0.616
7th - 0.742
6th - 1
5th -1.414
4th- 1.842
3rd - 2.872
2nd -3.146
1st - 4.484
Reverse - -2.882
Final drive 3.650:1
Gear ratio
6th - 0.683
5th - 0.780
4th - 0.844
3rd - 1.121
2nd - 1.952
1st - 3.727
Reverse -1.423
This Ford document (seems to) confirm that the my2024 Custom has the same gear spacing, but with final drive in a single 4.93 configuration (only used in over310 versions in the past)
mompracen_bs
Return to Transit Custom
