MK5 Crankshaft Pulley for two belts
Re: MK5 Crankshaft Pulley for two belts
Postby Peterr » Mon Aug 04, 2025 12:27 pm
No, my crankshaft pulley has a V belt for the power steering. The compressor has a 6 grooved pulley. So I need to change the crankshaft pulley to one with both V and 6 grooved (alternator and compressor) and change the power steering pulley to 6 groove. Which I have as I removed everything in the photo above. This is my current setup which I wish to modify for the compressor:
Keep on Transiting !
Peterr
Postby Peterr » Mon Aug 04, 2025 12:42 pm
BTW, thanks for the support !
I believe the part I need is this:
Not sure, still researching. I also need to swap the Lucas pump for a Bosch pump. So I need to be certain about the crankshaft pulley.
Peterr
Postby MinorMatt » Mon Aug 04, 2025 3:22 pm
Im not understanding why you need the V belt? The alternator, water pump, fan etc on all 2.5 Di and TD (with the exception of late mk2 transits) are all driven by a 4 rib belt (4Pk1483 on TD, 4PK1513 on non turbo) , the aircon is driven of a 6 rib belt.
Lucas EPIC or CAV? EPIC uses the same cambelt as bosch. (although the pulley you get will define if you use a 25mm or 28mm belt).
As said I have one like in your pic - but I don't think its what you need
Postby Peterr » Tue Aug 05, 2025 7:05 am
I’m still researching what I will need to add the compressor while still being able to swap from Lucas to Bosch. My current crankshaft pulley has a V belt to drive the power steering but the compressor has a 6 grooved pulley. Like I explained above I need to figure out what combination of belts and pulleys are needed to add the compressor.
Peterr
Postby MinorMatt » Tue Aug 05, 2025 8:31 am
If you have a lucas epic at the moment the cam belts are the same.
If you have a lucas CAV, then the cambelt has shallower & different profile teeth and will slip on any post 1991 crank pulley. Aircon was first fitted in 1994
Postby Peterr » Tue Aug 05, 2025 9:05 am
Mine is 2.5Di turbo from 1997 with a Lucas. I have a suitable Bosch with the pulleys. Not sure if I need to change the crankshaft pulley too. So to avoid removing the crankshaft pulley twice, rather fit the Bosch and compressor in one go. Still researching.
You’re correct, the alternator belt is 4 grooved. Has nothing to do with this project.
The crankshaft is V to drive power steering. After removing the radiator to access the timing belt and crankshaft pulley, the question will be if I can use your crankshaft pulley (with V+6 grooves) to turn both the power steering (with V) and the compressor (with 6 grooves) ? Or do I need to replace the V pulley on power steering with a 6 grooved pulley and run a longer belt.
Peterr
Postby Peterr » Tue Aug 05, 2025 9:29 am
Here are different arrangements:
Fourth photo is my current setup (no compressor)
Third photo is the engine I removed the compressor from
Second foto is the bracket I need to mount both compressor and power steering
First photo is an alternate V belt only arrangement.
I guess it won’t be clear until I’ve removed everything and mounted the bracket to see how it will all fit.
Peterr
Postby MinorMatt » Wed Aug 06, 2025 8:53 am
Peterr wrote:Mine is 2.5Di turbo from 1997 with a Lucas. I have a suitable Bosch with the pulleys. Not sure if I need to change the crankshaft pulley too. So to avoid removing the crankshaft pulley twice, rather fit the Bosch and compressor in one go. Still researching.
You will be fine with that, they bosch and the lucas at that age use the same cambelt
Mine is as per your images, 4 groove nearest cambelt and V outboard. I think I have seen the confusion now - the AC setup (as in one of your pics) mounts the PAS pump on the AC compressor support bracket and uses a 6 groove pully - running off the same belt as the AC - that pulley is part no 6992638 or 9443a73aa
This ebay link may be worth looking at ;)
https://www.ebay.co.uk/itm/187458291015 ... R6q67OWPZg
Postby mrepson » Tue Sep 30, 2025 11:21 pm
i could have a bottom pulley off a tourneo that had aircon,will have a look tomorrow
mrepson
Postby Peterr » Fri Oct 03, 2025 6:06 am
Thanks, curious does a Mondeo also uses a similar pulley?
Peterr
Users browsing this forum: glenandemm
