EGR A Control stuck closed
Postby tedtransit » Mon Oct 20, 2025 2:04 pm
Hello
my 2013 Transit T350 has developed the "EGR A control stuck closed ? I did have a maf sensor problem which I replaced (but due to work presure i did do around 600+ miles with the problem unresolved ) so not sure if related , the engine management light comes on and (sometimes) the stability warning light (which wont turn off ??)
hopefully someone can shed some light and what to do ?
thanks in advance
tedtransit
Re: EGR A Control stuck closed
Postby metalworker0 » Mon Oct 20, 2025 3:51 pm
I think the stability light comes on because it depends on everything being right with engine performance, EGR wrong .. so not right conditions for stability control because it eventually goes into limp mode because of the EGR fault
You need to dismantle and clean EGR... a garage may not do this 'cause of time versus price ... they will replace it.
Postby tedtransit » Mon Oct 20, 2025 8:55 pm
thanks for reply
Would it be better to just put a new EGR valve in as the van has done 140 k miles and being the b**+chit is to get at just dont want to do it again ?
thanks
tedtransit
Postby metalworker0 » Mon Oct 20, 2025 9:00 pm
Yes you can do .. but my advice: either Pierburg or a Ford one .
Postby knobby1 » Tue Oct 21, 2025 12:51 am
tedtransit wrote:thanks for reply
thanks
Get it mapped out and never worry about it again..!
Postby tedtransit » Tue Oct 21, 2025 5:44 pm
Well thats why it was stuck closd then ?? looks like it was jamed and the motor could not turn it, anyways as it was a total pain to get off and no doubt will be to get back on and as it may have burned out the motor i have orderd a new one
thanks for the replies
regards
tedtransit
Postby metalworker0 » Tue Oct 21, 2025 6:14 pm
so you've removed a cover off it ... and i see a roller bearing that's come out of the link bar... probably they are not supposed to do that so .. kaput .
