Transit Custom 2018 - Water ingress and electrical demons
Re: Transit Custom 2018 - Water ingress and electrical demon
Postby Altransit » Fri Nov 03, 2023 11:37 am
Thanks for posting back with the conclusion, we get too many threads where the OP just disappears without trace, so we never know if it was fixed or not :mrgreen:
Postby aldervai » Fri Nov 03, 2023 12:02 pm
Yeah, that drives me nuts. All take and no give. I've read so many where you just have to guess it was fixed by doing the last thing that was suggested. :D
aldervai
Postby aldervai » Fri Nov 03, 2023 12:09 pm
Roof rack
Rust on the subframe above the BCM
Dried, cleaned and painted
Hammerite floor
aldervai
Postby onjon » Mon Nov 03, 2025 6:27 pm
Is it not possible to remove BCM and dry it out?
onjon
Postby Radiofence » Mon Nov 03, 2025 9:32 pm
There are a number of posts on bcm and water ingress.
Mine included.
I had so many fault codes it was unbelievable.
Flux pen, solder sucker and many hours of soldering the 'through hole' pins.
Contact cleaner on the plugs and then contact sealing spray oil stuff, and mine was back on the road.
If the plugs havnt been cleaned, id worry your problems may return.
Well done for sorting, but u might not have needed to spend as much.
Transit custom 2.2
Radiofence
Postby Radiofence » Mon Nov 03, 2025 9:45 pm
Pics
Transit custom 2.2
Radiofence
Postby Radiofence » Mon Nov 03, 2025 9:46 pm
Soldered (constant soldering, sucking, fluxing, soldering.....)
Transit custom 2.2
Radiofence
Return to Transit Custom
