white smoke
white smoke
Postby fishing1974 » Mon Nov 24, 2025 4:17 pm
I've changed injectors head gasket changed serva white smoke
fishing1974
Re: white smoke
Postby knobby1 » Tue Nov 25, 2025 12:36 am
fishing1974 wrote:I've changed injectors head gasket changed serva white smoke
Would really help if you told us what model Transit you have..??
Mk6 or Mk7..?? Which engine..?? FWD or RWD..?? Euro-3, 4 or 5..??
Re: white smoke
Postby fishing1974 » Tue Nov 25, 2025 10:44 pm
mk7 2.2 euro 5 engine
fishing1974
Re: white smoke
Postby tranmx2 » Tue Nov 25, 2025 11:03 pm
Mk7 2006 to 2014. 2006 to sept 2011 different to 2011 to 2014 .
Year FWD RWD?
What is a serva?
Head gaskets have maybe 3 holes in them to show thickness of gasket. Gasket thickness determined by measuring from the top of the piston at TDC to the top of the block.
White smoke - too much fuel, unburnt fuel, water into exhaust possiblly from EGR cooler, head gasket, exhaust/vehicle in damp area.
tranmx2
