engine bay wiring harness code 57 plate
Postby Jagslag » Sat Sep 13, 2014 12:53 pm
I have a 57 plate SWB 2.2 FWD Transit that some twat has cut through the engine bay loom ,Fords want 500 quid for it.My Part number is 6C1T-12B637-HD ,my question is this can I put another wiring loom in with different suffix letters, e.g. JD..BD..AB..?
Mk7 Transit 2.2 swb 2008,Connect 2008,Fista van 2007.
Jagslag
Re: engine bay wiring harness code 57 plate
Postby ake » Sat Sep 13, 2014 4:07 pm
No, each suffix means a different loom, some are compatible, some are not
Postby Rollingbob » Wed Dec 03, 2025 6:30 pm
I have the same code - Air Con version with electric turbo actuator plug. Difficult to find it one on ebay though - all same to be non aircon eg 6C1T12B637JF
Rollingbob
Postby knobby1 » Wed Dec 03, 2025 7:49 pm
Rollingbob wrote:I have the same code - Air Con version with electric turbo actuator plug. Difficult to find it one on ebay though - all same to be non aircon eg 6C1T12B637JF
Thread is well over 11 years old, the person you're replying to hasn't been on here since May of 2015.
Postby Rollingbob » Wed Dec 03, 2025 9:49 pm
But still relevant
Rollingbob
Postby Rollingbob » Wed Dec 03, 2025 11:38 pm
Found one for £85, bit if a stab if it'll actually fix the dodgy starting issue lol but I've tried all the usual suspects: new starter, battery, crank/cam/maf sensor, fuel tank sender unit, fuel filter (put vaseline on all the pipe connections too but does still go quite empty), fuel filter housing...alternator working, no codes showing, grounds all good..
Rollingbob
Postby knobby1 » Thu Dec 04, 2025 2:33 am
Rollingbob wrote:But still relevant
Not when you're tagging a post onto a thread 11 years old and trying to talk to a person who hasn't been here for over 10 years.
Why not just start a new thread with your issue.?
Postby Rollingbob » Thu Dec 04, 2025 10:17 am
Don't want to overclutter
Rollingbob
Postby Rollingbob » Thu Dec 04, 2025 11:13 am
Rollingbob
