Mk6 Not starting
Re: Mk6 Not starting
Postby metalworker0 » Sun Dec 07, 2025 10:36 pm
So it's maybe a TDDI not TDCI
Difference is:
TDDI.. pump times the pulses of fuel to each individual pipe that supplies individual injectors.
TDCI. has electronic injectors fed by a common pipe known as a rail.. there is noticeable wiring going to each injector.
Postby Galway » Sun Dec 07, 2025 11:30 pm
Thanks.
It is definitely TDCI.
2010 Mk7 fwd 140hp T350 Camper
Galway
Postby knobby1 » Mon Dec 08, 2025 12:41 am
Galway wrote:Yip, and thanks, but based on last post, wondering which direction to take. This variant doesn't appear to have a PRV on fuel rail. One would expect such high pressures to have been diverted, or am I missing something?
PRV on the rail is only Mk7, normally the Mk6 TDCi PRV is part of the pump. They don't blow off until ~1600bar.
Fuel rail pressure is controlled by the metering valve, (SCV on a Mk7).
Lord Knobrot (Smithy)
Postby Galway » Mon Dec 08, 2025 12:51 am
Thanks Knobby.
This metering valve, is that the electrically operated one within pump?
He has replaced with a new one.
Or is there a purely mechanical one within that can be replaced?
Really at a loss with such high pressure and seems counter-intuitive to go replacing pump.
Any knowledge/ direction, really appreciated.
Galway
Postby knobby1 » Mon Dec 08, 2025 6:44 am
Galway wrote:Thanks Knobby.
Yes, essentially it will be just like the SCV on the Mk7, electroncally controlled via the PCM.
Postby Galway » Mon Dec 08, 2025 6:08 pm
Thanks very much knobby.
Galway
Postby Rollingbob » Mon Dec 08, 2025 7:28 pm
What if the fuel filter stays about half full and still tried a new filter/housing, starter, battery, crank/cam sensors, ignition switch, grounds reading good voltage, alternator good, no error codes, apart from the p0480 fan sometimes starting on poor cranking...
Have ordered a new engine wiring loom now and fuel filter pipes.
Luckily always starts back up on the jumper battery pack
Rollingbob
Users browsing this forum: avromo
