Thanksgt_addict wrote:Not sure if yours is EU4 or EU5. When we did a colleagues one (2.2 eu5 in a custom) it was 45nm then 120degs on the NEW bolt.
According to the diagram I have its one bolt.andz327 wrote:Crank pulley with one bolt ??
If it's 2.2 rwd its euro5
Feel how tight it is to slacken and just horse it back up until you can't
Dont buy a cheapo spurious pulley ..... with these you definitely get what you pay for
tranmx2 wrote:Remove bumper and rad' etc for easier access.
Might help with replacing your crankshaft pulley.
From 2012 E5 2.2. Nov 2022. Timing cover not aligned, seal distorted, found one hole in timing cover too small to allow alignment.
The 5 bolts are not screwed in.
There's other ways of doing this. About 33 ft lbs + 90 degrees for each of 3 bolts. Did get about 30 degrees.
viewtopic.php?f=5&t=235787
Just seen this Crankshaft pulley tool - for £19 is an easier way of doing it.
Looks like put the pulley on, the 3 bolts in place nip up. Put the tool on - with a socket through the larger hole tighten up the bolt - tighten all three then torgue up to spec.
A pipe to extend the lever part might be required.
Knobby2515 wrote:According to the diagram I have its one bolt.
Thanks for torques
Sent from my SM-A805F using Tapatalk
Must be wrong diagram your looking atKnobby2515 wrote:According to the diagram I have its one bolt.andz327 wrote:Crank pulley with one bolt ??
Thanks for torques
andz327 wrote:Must be wrong diagram your looking atKnobby2515 wrote:According to the diagram I have its one bolt.andz327 wrote:Crank pulley with one bolt ??
Thanks for torques
M3Stig wrote:still to this day i dont know what made ford pick a rubber pulley over a metal one, same with the wet belt although i have a theory behind that and its to make more money by getting them replaced as timing chains dont go wrong
