Part for mot?
Part for mot?
Postby Bat135 » Mon Jan 05, 2026 10:47 pm
Hi
I had an advisory on my mot. Pic attached.
What part do I need to order to rectify this? Is it just the L shaped track rod end near to the wheel? Obvious question I know. But just wanted to check.
I got the wheel bearing done. Just the other but I need help with as can fit myself.
Advice appreciated. Always very helpfull on here. Excuse my ignorance.
Bat135
Re: Part for mot?
Postby metalworker0 » Mon Jan 05, 2026 11:24 pm
yes the track rod you can do your self .
on the diagram its 3A130
pressing on that leads you down to the part number
which is: 1743642
http://www.catcar.info/ford/?lang=en&l= ... EzMQ%3D%3D
putting this into ebay with the word transit
gives you 1500 results
then it's up to you to spot the good stuff and exclude china rubbish
once fitted you'll be paying a hell of a lot more for the tracking to be done
Re: Part for mot?
Postby dumper » Tue Jan 06, 2026 12:30 am
Always check the tracking after fitting a track rod end if you count the turns when screwing it off and put it back the same I’ve had more that the tracking didn’t need adjusting but totally the opposite when changing the bottom wishbone they are usually way out
