What did you do to your mk6/7 today?
Re: What did you do to your mk6/7 today?
Postby loot » Wed Dec 03, 2025 1:01 am
ned wrote:
loot wrote:
Altransit wrote:[uote="loot"]I grew up in the 80s so as you can imagine, I wasn't able to say my goto respond ending in you f****g s****c
Bloody hell :lol:
That's an AI robot :evil:
They can only answer pre-programmed questions, so you'll get a generic answer to the nearest question they can find :lol: :roll:
You might be right Al, probably just as good to have had no response, like what has happened since I replied to them. Bloody Ford
AL has robots 8) I didn’t have all those questions just went on buy it now on the bay of e, just wish they did the carpet wheel arches as well, might have to use the stretch carpet on those[/quote]
I have since had a reply from the Y I robot(I think they're geordie) :lol: and she tried to put logic to it and that I needed to give the vehicle specific info so she could find out the info I requested. :lol:
Do you sell the carpet with the clips that it clearly is made for since the holes are there. You'd swear I was asking for the answer to the ultimate question of life, the universe, and everything. I get where she's coming from though.
07 350 170ps
Ids map here
loot
Postby Ivesy » Fri Jan 09, 2026 4:39 pm
loot wrote:Messing with van insurance quotes since reading Martin Lewis saying that insurance will double.
So my van will be 2.4 140ps rwd. 6 seats,(3 added in the back) alloy wheels added not standard. Full body kit, extra windows added.
Goes from standard £395 to added above £505. Which I think is furry muff really.
That's reasonable mate. I've done the same. Who did you get that with?
2011 T280 2.2 TDCI
2003 T280 2.0 Duratorq
2004 TT250R Yamaha
2011 XC250F KTM
Ivesy
Postby Ivesy » Fri Jan 09, 2026 4:44 pm
2011 T280 2.2 TDCI
2004 TT250R Yamaha
2011 XC250F KTM
Ivesy
Postby Airthies » Mon Jan 12, 2026 2:10 am
Pulled F39 as head lights were staying on with switch and ignition off.
Didn't bother looking into the issue as all the lights work as normal with the switch and ignition on.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Mon Jan 12, 2026 10:46 am
Airthies wrote:Pulled F39 as head lights were staying on with switch and ignition off.
Do you mean main beam? On my van sometimes i put main beam on and go to turn it on but it doesn't. I'm quite sure the relay sticks, bit nervous to use it as I don't like dazzling people. It's a latching setup isn't it.
07 350 170ps
Ids map here
loot
Postby Airthies » Mon Jan 12, 2026 11:15 pm
Just the dipped beam on both headlights.
I've no idea why F39 has any effect on the lights as that's for the Aircon.
Curious to the reason, I'm sure I'll find out why or will have another van by the time I get round to looking into it...
V86+patch
V86.04
X-Prog
C81
Airthies
Postby ned » Sun Mar 01, 2026 4:00 pm
Small job on fanny today, changed this
To this
I can now see the lovely green coolant/antifreeze levels
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby loot » Mon Mar 02, 2026 11:39 am
ned wrote:Small job on fanny today, changed this
To this
Should only use pink shouldn't you Ned :P
07 350 170ps
Ids map here
loot
Postby ned » Mon Mar 02, 2026 6:40 pm
To this
No idea, when I changed the coolant a few years back I just bought the prestone stuff, what’s the difference between pink n brown sorry I mean green :lol: :lol:
ned
Postby Airthies » Mon Mar 02, 2026 10:13 pm
Just performed a roadside front wheel bearing replacement.
.2hrs from home 7:30pm after a 5am start and a 340 mile trip so far,
Back on its boots by 8 and driving by 9pm
Just another 2hrs and 100mile to go down the A9 to be home.
At least the roads quiet now Image
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Altransit » Mon Mar 02, 2026 10:34 pm
Airthies wrote:Just performed a roadside front wheel bearing replacement.
Did you get Uber Eats to deliver the parts to you on the road? :lol: :mrgreen:
Good result buddy, glad that you got it home in one piece 8) 8)
Postby Airthies » Mon Mar 02, 2026 10:36 pm
Did you get Uber Eats to deliver the parts to you on the road? :mrgreen:
Not home yet.... ETA 11pm
And I carry a spare onboard. With the environment and work this girl does it's not uncommon unfortunately they're a semi consumable item
Would have been quicker if my special extractor tool wasn't in the workshop
V86+patch
V86.04
X-Prog
C81
Airthies
Postby loot » Tue Mar 03, 2026 10:52 am
ned wrote:
To this
Don't know, but if it chews through your delicate bits then you'll know :lol: tbh most coolant and things these days are harmless. I recall the old ac gas came with a don't expose this gas you'll all be dead kind of warning. Now they virtually come in a soda stream can :lol:
07 350 170ps
Ids map here
loot
Postby PizzaVan » Fri Apr 10, 2026 8:40 am
Programmed new key to the PATS. No struggling with remote programming. It won't go to programming mode :(
Making a food truck (Pizza Van) out of 2007 2.2 fwd.
From Estonia
PizzaVan
Postby Airthies » Fri Apr 10, 2026 9:29 pm
Birthday time for the big girl.
New boots. 255/70R16
New front disks n pads.
New front drive shafts outer CV boots.
New rear axle hub seal & while I was in there, swapped rear pad inners to outer as inside pads had about 40% wear and outers 60%
New timing chain cover since the temporary sealant repair had finally failed after over a year and started leaking again.
And a new drive belt while the front was off as it was cracking.
V86+patch
V86.04
X-Prog
C81
Airthies
