Adblue light straight away on ignition on
Re: Adblue light straight away on ignition on
Postby metalworker0 » Tue Jan 13, 2026 5:59 pm
you said something up there about temperature fluctuations, I know the ecoblue has this function, don't know if a 2015 2.2 transit will have it.
The ecoblue with stop start has a system on it with an extra electric coolant pump that directs coolant to the passenger compartment heater when its in stop start mode ... so your engines NOT RUNNING and its being cooled by this function, just so you can stay warm inside the cabin,.,,, so i imagine the ecoblue (don't know about yours or if all stop start function in this way ) is going through extreme cooling a heating cycles when its in stop start mode.
Postby Ryan9153 » Tue Jan 13, 2026 6:26 pm
metalworker0 wrote:you said something up there about temperature fluctuations, I know the ecoblue has this function, don't know if a 2015 2.2 transit will have it.
I’ve turned the stop start off bud, my only fault code now is P0420 catalyst efficiency bank 1 below threshold most searches say it’s either exhaust leak which it isn’t, engine misfire etc which it isn’t, catalytic converter itself maybe?, nox sensors which are both reading the same so I doubt it but still possible I suppose, I’m thinking remove cat and dpf and clean and inspect both while they are off, what you reckon?
Ryan9153
Postby metalworker0 » Tue Jan 13, 2026 6:38 pm
catalyst efficiency a few weeks ago we discussed this with FRAG on the connect forum .. he reckoned
catalyst below efficiency could be a cracked catalyst . as well as according to AI exhaust leaks, faulty oxygen sensors, engine misfires, or excessive unburnt fuel.
I'm not quite sure how these combined DPF's and catalysts work though, if it has that set up .
Postby Frag » Tue Jan 13, 2026 7:32 pm
I think this is heading towards the DPF itself being faulty,but that’s always the last thing I’d want to condemn
Knowing how expensive they are.
As you haven’t mentioned it so far,I’d be checking the vaporiser next.
It’s free to check,and if you don’t,and then fit a DPF it may not fix the fault and you’d still need a vaporiser…..
Do you have access to,or can you borrow a ‘mityvac’. ?
Frag
Ford Technician
Postby Ryan9153 » Wed Jan 14, 2026 7:56 am
Frag wrote:I think this is heading towards the DPF itself being faulty,but that’s always the last thing I’d want to condemn
So I will get hold of a mityvac but surely as the regen starts and gets halfway through the vaporiser is working? I think I need more knowledge on how this particular emissions system works. Again many thanks today I’m going to take off the dpf and cat and obvs all parts in the exhaust and inspect and test where I can, could it not be as simple as needing the nox sensors reset? Like telling the ecu they have been changed so it recalibrates.
Ryan9153
Postby Ryan9153 » Wed Jan 14, 2026 11:04 am
So I took off the cat and forced air through it, it seems to be totally free airflow as well as the dpf, I forced air through that it seems clear. I’m pretty sure the dpf is not blocked. I’m trying to take the vaporiser off next but access is limited, getting any heat onto it is nigh on impossible. As metalworker suggested is the cat cracked and how would I identify that with this type of cat it’s very hard to see inside it?
Ryan9153
Postby Frag » Wed Jan 14, 2026 2:45 pm
So the vaporiser can get blocked with carbon and soot,then the diesel that’s pumped into it when active can’t get through and causes issues.
This is where the mityvac comes in,you don’t need to remove vaporiser from exhaust.
Remove the fuel supply pipe from vaporiser itself,put mityvac onto that pipe on vaporiser,set mityvac to vacuum,you should not see the guage move at all when pumping mityvac,if it pull vacuum and holds it,it’s totally blocked.
If it reads a vacuum that slowly drops away,it’s partially blocked.
You need to see no reaction from guage at all.
Also this far into the problem,it might be wise to try and find out if PCM and SOBDMC (ad-blue) module software are at latest (Ford) levels.
Frag
Ford Technician
Postby metalworker0 » Wed Jan 14, 2026 4:16 pm
Well as far as seeing whats going on
A camera probe .. boroscope etc
You can now get them cheap for use with a mobile phone
mityvac.. expensive bit of kit
Would this do instead
https://www.ebay.co.uk/itm/389486040517?
As regards vacuum etc, cheapest method , for all time and memorial, ive always done it this way, to check if somethings holding vacuum:-
Put tube on it and suck, whilst doing so, quickly cover end of tube with tongue of bottom lip ... if it continues to hold/ stick to your lip or tongue .. then its holding vac .
Postby Ryan9153 » Wed Jan 14, 2026 6:26 pm
Frag wrote:So the vaporiser can get blocked with carbon and soot,then the diesel that’s pumped into it when active can’t get through and causes issues.
Hi bud thanks ordered a mityvac today wasn’t too bad only £128 so we will see, tried to get vaporiser off but it def needs heat or I will risk damaging it or the threads, so got to wait for the mityvac to arrive. This job is costing a small fortune so need to get the part diagnosis right not fire the parts canon.
Ryan9153
Postby Ryan9153 » Wed Jan 14, 2026 6:28 pm
metalworker0 wrote:Well as far as seeing whats going on
Hi Mark ordered myself a mityvac today wasn’t£128 so hopefully that will do the trick, also ordered a laser borescope around £228 plus vat I think so see if these two items aid me with diagnosis. Cheers bud
Ryan9153
Postby metalworker0 » Wed Jan 14, 2026 6:42 pm
Spending money, or even telling others to spend it, makes me sweat.
so I always try to give alternatives.
all the best mark
Postby Ryan9153 » Wed Jan 14, 2026 9:25 pm
Hi Mark yeah I understand that bud, I’m trying to keep costs down but they are already high.
Ryan9153
Postby Ryan9153 » Fri Jan 16, 2026 7:24 am
Hi guys so spent most of yesterday do the front discs and pads, then trying to get the vaporiser out, it just won’t budge, was just trying to get it out to clean it but think I’m going to wait for the mityvac, it’s completely seized in. I’ve got the headlight out, air filter box out, moved power steering bottle and washer fluid filler neck and I’ve got fairly good access to it now, applied heat but she still won’t budge, any tricks guys cos I’ve got a feeling replacing it is going to be the only way forward, exhaust might have to come off completely.
Ryan9153
Postby Ryan9153 » Fri Jan 16, 2026 10:51 am
Hi guys so update, hope you don’t mind me updating posts, I’m doing up so that it might help other members in the future, I see too many posts with no conclusions so loads asking did you solve it. Anyway so finally got vaporiser off and Frag you were right at least about the vaporiser it was completely blocked, I’m now cleaned it out and reinstalled it, so we will see. Just got to put her all back together then test drive fingers crossed.
Ryan9153
Postby Ryan9153 » Fri Jan 16, 2026 1:19 pm
So further update test drove today for over an hour carry out regen, not as I expected went down to around 20% soot content and inferred loop of 2% then regen stopped normally no codes, carried on driving not sure what these two data parameters are but as I got back dpf soot was on 45% and inferred loop of 10% but def no fault codes so I believe we are all good. Many, many thanks guys hope that’s her fixed now.
Ryan9153
