Mk 7 2.2 cuts out when cold
Postby firstaiddressing » Tue Mar 06, 2012 11:23 pm
Hi Chaps Ive just bought a very tidy 2008 SWB low roof panel van 90000 miles, goes like sh*t of a shovel but in a morning when cold it keeps cutting out and the rev counter is up and down, it runs smooth for say 3-5 seconds then rev counter drops then it picks up then drops and cuts out, it gets better as it warms up but even then i feel its dropping slightly on tick over...never had a diesel that does this its more like a petrol engine would run when cold, any ideas please.
Bill.
firstaiddressing
Re: Mk 7 2.2 cuts out when cold
Postby mobilevanman » Tue Mar 06, 2012 11:28 pm
i would get codes read first and see if fuel pressures are correct may indicate a fault but defo the first step
why not if u dont someone will
mobilevanman
Postby ake » Wed Mar 07, 2012 8:14 am
That probably wants a prv followed by pilot/pump learn and PCM update by Ford IDS system
Postby firstaiddressing » Wed Mar 07, 2012 1:28 pm
thanks lads for you advise on this.
Van Had code check this morning nothing showing
Ive had the van serviced today new fuel filter and oil change etc but still surging, the mechanic seems to think pilot pump as theres air looming about in the transparent fuel line
the pump seems to be pulsing but no fuel coming out.. does this make sense ?? any ideas please.where is the pump anyway???
also do you kow the cost of one of these units are they ford only and is it compulsory for the PCM update check
Cheers.
Bill
firstaiddressing
Postby firstaiddressing » Thu Mar 08, 2012 6:37 pm
Ake your a genius thanks mate.
I had the van in the technical operating theatre this afternoon,it was hooked up for around an hour and a half the guy did the pump learn and ford IDS its running like a swiss watch cant belive the difference,
THANK YOU VERY MUCH!!!
Bill
firstaiddressing
Postby ake » Thu Mar 08, 2012 9:35 pm
firstaiddressing wrote:Ake your a genius thanks mate.
Bill
Happy days :D
Thanks for letting us know the outcome :wink:
Postby ciaranpoole » Sat Jan 17, 2026 11:59 am
good morning all i have the same issius as stated above what was the fix please and a rough cost of all this ive changed diesel filter housing ect and only in cold weather does it do this im also having similar issues with the rpm going up and down almost like spraying brake cleaner into it and it revs up then dies down and Chugg's to eventually turn off then when trying to start it wont turn over just cranks until you go under bonnet and press the primer bulb and then the van will start and be fine for a few days before it does it all over again
ford transit mk7 2008 2.2 duratorq
any help is much appreciated
thanks
ciaran
ciaranpoole
Postby knobby1 » Sun Jan 25, 2026 9:37 pm
ciaranpoole wrote:good morning all i have the same issius as stated above what was the fix please and a rough cost of all this ive changed diesel filter housing ect and only in cold weather does it do this im also having similar issues with the rpm going up and down almost like spraying brake cleaner into it and it revs up then dies down and Chugg's to eventually turn off then when trying to start it wont turn over just cranks until you go under bonnet and press the primer bulb and then the van will start and be fine for a few days before it does it all over again
thanks
ciaran
Thread is 14 years old...the person you're replying to hasn't been here for 10 years. You'd be better off starting a new thread with your issue.
What you're pressing on the filter housing is "not" a primer bulb...it's a filter clogging indicator.
When were the learns last done..??
Lord Knobrot (Smithy)
Postby cristianbells » Tue Mar 31, 2026 4:33 pm
firstaiddressing wrote:thanks lads for you advise on this.
Cheers.
Bill
Also, is there a way to properly test the pilot pump before replacing it, just to be sure that’s the actual issue? I’d rather not throw parts at it if it could be something like an air leak or blockage in the line.
And if anyone has had the same issue before, did replacing the pump solve the surging completely, or should I be looking at anything else alongside it?
cristianbells
Postby knobby1 » Tue Mar 31, 2026 8:15 pm
Cheers.
Bill
The person you're replying to hasn't been here since April of 2016, near 10 years ago.
You're best off starting a new thread with your problem....new posts tend to get lost in very old threads.
What's a "pilot pump"..??
