Ford Transit 2019 minibus Parkng aid fault
Postby Ryan9153 » Mon Jan 19, 2026 4:43 pm
Hi Guys got a transit minibus where the Parking aid malfunction is on the dash, scanned it with forescan and it comes up with all four rear parking sensors at fault which I doubt to be true must be wiring or module itself surely.
Codes are B1B44:31-2A same but 46,48 and 50 are the other fault codes. Input most welcome.
Ryan9153
Re: Ford Transit 2019 minibus Parkng aid fault
Postby knobby1 » Mon Jan 19, 2026 8:00 pm
Ryan9153 wrote:Hi Guys got a transit minibus where the Parking aid malfunction is on the dash, scanned it with forescan and it comes up with all four rear parking sensors at fault which I doubt to be true must be wiring or module itself surely.
Have you physically checked the wiring and/or connectors to make sure they're not damaged/corroded..??
Postby Ryan9153 » Mon Jan 19, 2026 9:49 pm
Checked the wires on the back behind bumper looks ok no corrosion that I can see but very wet, loom looks ok but haven’t opened it up yet.
Ryan9153
Postby Frag » Mon Jan 19, 2026 10:41 pm
If you can’t see any signs of trapped or damaged wiring initially,and loom to main harness multiplugs not corroded,before you start pulling loom to bits,try disconnecting each sensor individually and clearing/re-reading codes.
1 bad sensor can bring all 4 down and give that fault.
If you unplug that faulty one you’ll then just get a dtc for that particular one being open circuit,not all 4.
Frag
Ford Technician
Postby Ryan9153 » Wed Jan 21, 2026 8:30 pm
Frag wrote:If you can’t see any signs of trapped or damaged wiring initially,and loom to main harness multiplugs not corroded,before you start pulling loom to bits,try disconnecting each sensor individually and clearing/re-reading codes.
Roger that bud will try that tomorrow and get back to you.
Many thanks.
Ryan9153
Postby Ryan9153 » Tue Jan 27, 2026 6:34 pm
Many thanks.
Disconnected rear right sensor put back and codes cleared so not hold in my breath but we will see.
Ryan9153
