Full lock weird noise
Full lock weird noise Alternator pulley change
Postby Harrypalmer » Sun Jan 25, 2026 8:47 am
Hi All
I’ve watched the video earlier in this thread and the guy used a big Alan key to remove the alternator pulley. It does seem like a big Alan key will fit into the end of the pulley see photo attached however I have bought an alternator Toole set but there isn’t a big Alan key in there to fit into the end of the pulley, so now I’m not sure which is the correct method to remove the pulley. Any guidance much appreciated.
Ford Transit 2019 eco Trend Panther diesel 2.0 mk7 V363 manual
Harrypalmer
Re: Full lock weird noise
Postby Harrypalmer » Sun Jan 25, 2026 9:28 am
Problem solved. Didn’t know there were different sized alternator tool kits!
Harrypalmer
Postby Frag » Sun Jan 25, 2026 11:51 am
Does the adaptor in the kit you bought not fit ?
Frag
Ford Technician
Postby Harrypalmer » Mon Jan 26, 2026 9:25 am
Hi Frag
No unbelievable it doesn’t fit. But I’ve bought another adapter I needed 17mm nut. Not 22mm as in the kit
Harrypalmer
Postby Harrypalmer » Mon Jan 26, 2026 9:29 am
The key nut was 22 mm
The inside of the pulley is 17mm
Harrypalmer
Postby Frag » Mon Jan 26, 2026 11:26 am
Yeah,I’ve just checked our tool and it’s 17mm
Be aware though,The pic you’ve posted of the other tool above shows the splined adaptor.
(Unless it’s another full kit including 17mm adaptor)
Frag
Ford Technician
Postby Harrypalmer » Wed Feb 11, 2026 8:22 pm
FINALLY, on the 3rd attempt, they have sent the correct pulley removal tool AND new alternator pulley.
Harrypalmer
Postby Harrypalmer » Fri Mar 06, 2026 10:54 am
SOLVED. Cheers Frag and all for advice.
Alternator pulley changed and noise has stopped and all good
H
Harrypalmer
