new to me 2014 mk8 trend. what windscreen camera do?
Postby riauba » Sun Jan 25, 2026 10:41 pm
hi, just bought 2014 mk8 rwd trend van. usual bells and whistles like parking sensors, reverse camera, led drl. windscreen also has camera fitted. drove it in the dark and it doesn't switch high beam automatically, so it's not that, can't see any lane assist buttons and there wasn't warnings changing lanes without indicator on motorway, so what is it for? emergency brake maybe? Vin report doesn't say anything, or at least I can't see. It has auto wipers, but mk7 transits didn't need camera for that. here is the specs sheet: Date of production 11/17/14
Vehicle Line Transit 2014-
Positive Territories (+)"GB"
Engine Type 2.2L CR TC I4 DSL 125 PS
Transmission 6 Speed Manual Transmission-MT82
Emission Requirements Stage V LDT3 Emissions
Drive RHD RWD
Final Drive Ratios 3.15
Series 1.7-350L Series
Cab Style Regular Cargo Van
Exterior Paint Frozen White
Interior Fabric Lane/Max Charcoal Black
Equipment
A/V Jack With A/V Jack
Accessory USB Unit Accessory Media Hub 1XUSB
Alternator Types Standard Duty Alternator
Anti-Lock Brakes Brakes-ESP/HLA/FBS
Auto Headlamps With Auto Headlamps
Batteries Heavy Duty Battery
B Pillar Assist Handle With B Pillar Assist Handle
Bulkhead & Partitions With Full Partition - Steel
Cold Start Type Cold Start Up To -20%c
Configurable Unlocking Configurable Unlocking - Conf 1
C To C Alternatives Rear Axle Alternative A
Diesel Particulate Filter With Diesel Particulate Filter
Door Auto Relocking With Door Auto Relocking - Enabled
Door Handle - Exterior Exterior Door Handle - Black
Door Locking Systems Power Door Deadlocks - Shielded
Door Remote Control Unit Remote Control Door Entry - 2 Fob
Driver Door Mirror Type Large Head/Short Arm Mirror
Drivers Air Bag With Driver Air Bag
Drivers Seat Adjustment Type Drivers 4-Way Man With Cushion Tilt
Drivers Seat Armrest With Drivers Seat Armrest
Dual Rear Wheels With Single Rear Wheels
Electrical Outlet Electrical Outlet
Electronic Speed Limitation Electronic Speed Limiting Device
Emergency Hammer LESS EMERGENCY HAMMER
Exhaust Exit With Down Turned Exhaust Exit
Exterior Mirror Dual Dual Exterior Power Mirrors-Power Fold Back
Exterior Paint Pack Exterior Paint - Solid
Exterior Tailgate Handle Lift/Bootlid Handle Exterior-Black
Footwell Lights With Footwell Lights
Fresh Air Heater With Recirculating Heater
Front Bumper Front Bumper - Partial Body Colour
Front Fog Lamp Type With Front Fog Lamps
Front Grille Types With Grey Grille
Front Gross Axle Weight Rate Front Axle Rating-Normal
Front Headrests With Front 2 Way Headrest
Front Parking Aid With Front Parking Aid
Front Seatbelt Type With Inertia Front Seat Belt
Front Seat Type With Sngle.L/B Dvr/Dual L/B Pass.St
Front Window Operation Power Front Windows One Touch Up/Do
Fuel Capability Type With Diesel Fuel Capability
Fuel Tank Filler Neck Fuel Tank Fill Neck-With Inhibiter
Fuel Tank Lock Non Locking Capless Fuel Fill
Fuel Tank Types With 80 Litre Fuel Tank
Gearshift Knob With Leather Gear Shift Knob
Glove Box Lid With Locking Glove Box Lid
GVM Rating With Standard GVM Rating
Header Mounted Map Reading
Lamps
Header Mounted Courtesy/Maplights
Headlamp Control With Automatic Headlamp Control
Headlamp Levelling Type With Front Headlamp Levelling
Headlamps - Daytime Running With Daytime Running Lamps
Headlamps - Design With Halogen Headlamp
Headlamps - Type Headlamps-Static Bending
Headlinings With Partial Headlining - Moulded
Heated Windscreen With Heated Windscreen
High Mounted Stop Lamp With High Mounted Stop Lamp
Hill Launch Assist With Hill Launch Assist
ICE Feature Pack Ice Feature Pack 4
In Car Entertainment ICE- Low Audio (0C)
Instrumentation Type With Conventional Instrumentation
Instrument Cluster - Rheostat With Instrument Cluster - Rheostat
Integrated Control Panel Midline ICE ICP
Interior Cladding Surface Interior Trim Accent Pack B
Interior Environment Colour Interior Environment Colour-Pewter
Interior Feature Colour Int Feat Colour - Charcoal Black
Load Compartment Lamp With Load Compartment Lamp
Load Compartment Tie Down
Loops
With Load Space Tie Down Loop
Load Floor Covering Load Floor Liner-Molded
Lock Group Power Lock Group-Speed Dependent
Lumbar Seat Support Driver Seat With Drivers Manual Lumbar Support
Marketing Levels Marketing Level 4
Media Gateway Module With Media Gateway Module
Microphone Microphone
Mid Bodyside Moulding Type Wide Bodyside Moulding-Grey
Multi Function Display Matrix Multi Function Display
Overhead Console With Standard Overhead Console
Parking Brake - Function Type With Mechanical Parking Brake
Passenger Floor Covering Floor Cover - Rubber Ins-Partial
Passenger Seat Adjustment Type With Pass 2 Way Manual Seat Adjust
Plant Build Requirements Otosan (Turkey) Plant Build
Radio Antenna Type Roof Mounted Radio Antenna
Radio Speakers Radio Speakers-2 Woofers/2 Tweeters
Rear Bumper Rear Bumper - Plastic Unpainted
Rear Compartment Trim Panel Side/Rear Door Trim Panel-Level 1
Rear Door Edge Warn Lamps Rear Door Edge Warn Reflectors
Rear Fog Lamps With Rear Fog Lamps
Rear Loading Door With Hinged Rear Loading Doors
Rear Mudflap Type With Rear Mudflaps
Reverse Parking Aid With Rear Parking Aid
Roof Height With Medium Roof
Roof Storage-Driver Roof Storage-Driver Sunglasses
Seat Belt Pre-Tensioners Seat Belt Pretensioner - Drivers
Seat Belt Warning Type St Belt Minder-Drvr/EU Tel&Snd
Seat Pack Seat Pack 13
Side Load Door Opening With Unrestricted Side Load Dr Opng
Side Load Doors With Kerbside Side Load Doors
Single Note Electric Horn Dual Note Electric Horn
Spare Wheel Type With Steel Spare Wheel
Speed Control With Speed Control
Speedometer Types With MPH/KMH Speedometer
Starter Motor Type Standard Electric Starter Motor
Steering Column Types With Manual Tilt/Slide Stg Column
Steering Wheel Radio Controls With Steering Wheel Radio Controls
Steering Wheel Type Leather Steering Wheel
Sunvisors - Driver Sunvisor Less Mirror - Drivers
Sunvisors - Passenger Sunvisor Less Mirror - Passenger
Tinted Glass With Tinted Glass All Round
Tire Tread Pattern - Front/Rear With Standard Tread - Any Vendor
Tool Kits With Tool Kit
Tray/Table - Front Seat Tray/Table - Front Seat
Tripminder With Trip Computer
Two Step Door Unlocking Two Step Door Unlock System
Tyre Carrier Opener Tyre Carrier Drop-Dr Open
Vehicle Status Complete Vehicle
Visibility Pack With Visibility Pack High
Washer Tank Level Warning Lamp Washer Tank Level Warning Lamp
Wheel Covers With Full Wheel Cover
Wheel Lug Nuts Non Locking Lug Nuts
Wheel Size & Style 6.5 X 16" Steel Road Wheel
Windscreen Wash/Wipe With Automatic Windscreen Wiper
riauba
Re: new to me 2014 mk8 trend. what windscreen camera do?
Postby Altransit » Sun Jan 25, 2026 11:00 pm
Forward camera can do a few things depending on what is fitted to your van:-
1/ Speed limit sign detection
2/ Auto dipping headlights (yours could be disabled in the menu)
3/ Forward alert - detects if you're approaching the rear of a vehicle too fast (not sure if it brakes, or just makes an alarm noise)
4/ Lane assist (again, can be disabled)
I have all of these on my Focus, and none of them work reliably :roll:
Postby riauba » Sun Jan 25, 2026 11:22 pm
not sure if sign detection was available on 2014 transit, for auto high beam even my g05 bmw has button on stalk, but on transit i didn't notice.
riauba
