2011 Rear Hub Torque Spec
Postby overdraft » Mon Feb 23, 2026 9:00 pm
Hi All!
Replacing one of my rear hubs (failed bearing) and I just need a torque spec for the nut.
I promise I searched in the forum and the greater web, but either it's not out there or my prompt skillz are lacking.
Thanks in advance if anyone has the number!
overdraft
Re: 2011 Rear Hub Torque Spec
Postby metalworker0 » Mon Feb 23, 2026 9:26 pm
not sure when drum became disc ,. so you have to say disc or drum
All the best.mark
Postby overdraft » Mon Feb 23, 2026 9:51 pm
metalworker0 wrote:not sure when drum became disc ,. so you have to say disc or drum
All the best.mark
Thanks for that... I assumed the transition would have been when the model changed!
DRUM.
overdraft
Postby metalworker0 » Mon Feb 23, 2026 10:16 pm
Yes looks like mk1 had drums only on the rear. i could be wrong... i thought some had discs
all there is in the manual is drums.
you are going to need a big torque wrench maybe 3/4 drive
340 Nm
251 lbs foot
Postby metalworker0 » Tue Feb 24, 2026 12:25 am
I found rear disc brakes in the manual
its very hard to search the manual --2797 pages, no index ... and search words are either one word or two words that you know come after each other. rush it and you'll crash it
so for the record mk1 did have disc brakes on the rear on some models.
Postby g-man » Tue Feb 24, 2026 9:11 am
metalworker0 wrote:Yes looks like mk1 had drums only on the rear. i could be wrong... i thought some had discs
340 Nm
251 lbs foot
Yep some do,have them on my MK1(07).
g-man
Postby overdraft » Fri Mar 13, 2026 7:45 pm
wait, does someone have a link to the manual????
overdraft
Postby metalworker0 » Fri Mar 13, 2026 9:31 pm
No .. the manual was given to me by a member of the forum .. he paid full price for it and does not like the idea of me giving it away.
So .. all i can do is look through it with any questions you want to ask about, copy a pages or diagrams that is it.
if i ever find a free one online , ill put a link to it .
Note: most or nearly all manuals you find shared online are someone ripping off a pay-for manuals site .. who show the manual and remove chunks of important info out of the "incomplete SAMPLE"of it, so its not much cop...Or the sample is good .. but chunks go missing when you try to copy it.. that's what some are like from ebay.
Not ever managed yet, to get the mk6/7 one that isn't missing bits.
Even with the paid for ones Non of them are indexed and properly searchable......they are just a giant 3000 page toilet roll, with the facts hidden inside somewhere!
There is a Haynes manual that is available .. but its not very good .. pics and diagrams are not good .. information not detailed enough (does not even show the drum brake diagram).. unlike a Haynes from the 6O's 70's 80;s and early 90's
USA has proper very detailed genuine Ford paper manuals on the Connect .. but they don't have the same engine and the electrics are in another manual.
Postby overdraft » Mon Mar 16, 2026 11:11 pm
For the drum brake version, does anyone know how big the hub nut is?
I don't want to have it pulled to pieces only to find I don't have the right size socket....
TIA!
overdraft
Postby metalworker0 » Mon Mar 16, 2026 11:53 pm
NOPE .. nothing in manual on its size
part number is 4388061
from ford less than £5.00 when in stock .. everywhere else considerably more
