What relay 2017 AdBlue Custom?
Postby SilverSteve » Mon Mar 09, 2026 7:34 pm
Hi,
I've been having some problems with my electric windows, the passenger side is only going down, not up. I think its the wiring looms in the doors so I've changed them, but haven't tried it yet. During my figuring out process I was checking fuses and like an idiot I took out a green relay and dropped it down inside the wing. I would like to get it out, but can't see how, and suspect its going to be another irritating rattle. My problem is that Ford parts don't know which relay it is from the attached screenshot, but I don't have the old one to get a code from. Can anyone please help?
It's from the fusebox below the steering wheel, on the right hand side nearest the wing.
The van is a 2.0l AdBlue Transit Custom. I think it was the first year with the newer engine, but has the older model interior.
Just to say: been a member of the forum a few times, but not recently. I've had a works van for quite a few years so this one wasn't being used much. Now that I need it back on the road regularly, the damn thing plays up which is typical!
Thanks in advance,
Steve
SilverSteve
Re: What relay 2017 AdBlue Custom?
Postby metalworker0 » Tue Mar 10, 2026 6:00 pm
This is as near as i can get you.
You have three owners manuals to choose from.
Goes by build date not reg date, or you can step back one page and put YOUR vin number in.
https://www.ford.co.uk/support/vehicle/ ... er-manuals
In the manual will be the fuses section, where you'll be a displayed a page with diagrams of fuses in fuse boxes and what they cover.
Note: common problem, wiring from door to "A" Pillar can break inside the conduit.
Postby SilverSteve » Tue Mar 10, 2026 10:40 pm
Thanks Mark, I'll give it a try!
SilverSteve
