andz327 wrote:you can fit just about any seat, the drivers seat box also fits directly onto passenger side as well and easiest way is two bits of flat bar bolted across seat box then new seat bolts onto flat bar , only thing to watch is thickness of seat base/ cushion in case your sitting to high and your thighs end up against the steering wheel , i used vw seats, then Galaxy swivel base seats, now you can buy universal swivel base for any seat out of Temu for less than 40 shekels , I'm using 2017 vauxhall crossland seats at the moment and driver has armrest and are comfortable, cost including postage for the pair was around 160 shekels
still built in lolStevelien wrote:andz327 wrote:you can fit just about any seat, the drivers seat box also fits directly onto passenger side as well and easiest way is two bits of flat bar bolted across seat box then new seat bolts onto flat bar , only thing to watch is thickness of seat base/ cushion in case your sitting to high and your thighs end up against the steering wheel , i used vw seats, then Galaxy swivel base seats, now you can buy universal swivel base for any seat out of Temu for less than 40 shekels , I'm using 2017 vauxhall crossland seats at the moment and driver has armrest and are comfortable, cost including postage for the pair was around 160 shekels
Nice seat. What did you do with the built in seat airbag?
