Coolant/Degasser consumable Caps
Postby VentaBlack » Sun Mar 15, 2026 10:03 am
Hello.
MOT season again for me.
And yet another coolant expansion tank Cap stuck in orifice.
I've gotten previous one out using the destructive method.
But it baffles me how this much vacuum occurs, and is there an old-style metal cap option hidden on the market?
2013
mk7 LR
2.2 fwd
about 160k
VentaBlack
Re: Coolant/Degasser consumable Caps
Postby T350camper » Sun Mar 15, 2026 11:52 am
I've not had this problem before but if you can't pull the remnants of the cap out with pliers etc, then perhaps try removing the header tank. This will eliminate any vacuum but if that doesn't help, you could apply internal pressure from an airline or electric tyre pump or something. Sounds like it's either too tight a fit or the seal has expanded making it jam.
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Postby knobby1 » Sun Mar 15, 2026 7:48 pm
VentaBlack wrote:Hello.
2013
mk7 LR
2.2 fwd
about 160k
Get a genuine Ford cap...the one in the pic is not genuine.
Lord Knobrot (Smithy)
Postby VentaBlack » Sun Mar 15, 2026 8:12 pm
Thanks for replies.
I can get them out when they get stuck in, but it's a destructive process.
Hence, buy a few cheap ones and keep in GB.
The Ford site is a Troglodytes nightmare, classic "computer says No" programming. . . .
I'll buy a Ford one, see how long it lasts.
VentaBlack
Postby knobby1 » Sun Mar 15, 2026 8:31 pm
VentaBlack wrote:Thanks for replies.
The one in my 2008 2.4 140 is the original, so 18 years old and still works fine.
Postby andz327 » Wed Mar 18, 2026 2:58 am
VACUM isn't the problem it's after market cheapo parts , cheap cap then possibly cheap expansion tank = broken stuck parts
andz327
