Reverse light switch gear box
Postby cristiansure » Fri Apr 05, 2024 11:07 pm
I have a Mk6 Transit with the 6 speed gearbox. For a while I've had issues with intermittent reversing light operation. When they finally stopped working altogether I sourced a replacement switch and verified that the lights worked when the switch was operated manually, it turns out that my reversing lights still don't work, or only very rarely. All I can assume is that whatever actuates the switch inside the gearbox is not doing so correctly.
Has anyone else come up against this issue?
cristiansure
Re: Reverse light switch gear box
Postby tranmx2 » Sat Apr 06, 2024 6:27 am
There is a post about the actuator within the gearbox.
2012 2.2 TDCi MK 7 E 5 100 HP - 350 3.5 tonne XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP. Siemens Continental fuel system.
OBD2 ELM 327 FTDI Forscan 2.3.46
tranmx2
Postby knobby1 » Sat Apr 06, 2024 9:50 pm
cristiansure wrote:I have a Mk6 Transit with the 6 speed gearbox. For a while I've had issues with intermittent reversing light operation. When they finally stopped working altogether I sourced a replacement switch and verified that the lights worked when the switch was operated manually, it turns out that my reversing lights still don't work, or only very rarely. All I can assume is that whatever actuates the switch inside the gearbox is not doing so correctly.
Being a Mk6 6 speed, it must be a TDCi 2.4 135 RWD..?? Some of the "aftermarket" switches aren't quite long enough to reach the reverse actuator, is it a genuine switch..??
Postby Tonecamc » Wed Mar 25, 2026 9:12 pm
Hi there I’m new here although I’ve got transit for some time now. I also got problem with reverse light coming up.
It’s probably the thing that’s actuating the switch. Can someone send a link to the discussion that’s about that or recommend what to do here. Thank you!
Tonecamc
Postby DanMK7uk » Wed Mar 25, 2026 10:15 pm
Tonecamc wrote:Hi there I’m new here although I’ve got transit for some time now. I also got problem with reverse light coming up.
Coming up ? Stuck on or not working ?
DanMK7uk
Postby Tonecamc » Thu Mar 26, 2026 10:21 am
Hi sorry for not being clear and thanks for the response.
So it’s not working. The lights are not working when I select the reverse gear, but the reverse is working.
I’ve changed the switch still same. If I go into reverse and then come back a bit there is some kind of click on the lever and the lights at the back are lighting up, I’ve connected camera that’s how I know. The switch was identical with the old one is on the gearbox. Vehicle is transit 2011 rwd 2.4l mk7
Tonecamc
Postby gt_addict » Thu Mar 26, 2026 6:59 pm
If you’ve changed the switch for a genuine new one then I would be looking at gear linkages from the dash to the box. Maybe theres some play in something which means it doesn’t activate the switch on the box properly.
gt_addict
Postby Tonecamc » Fri Mar 27, 2026 11:33 am
There is repair to one end of the linkage but it’s not moving don’t think that could be the problem
Tonecamc
Postby chalo73 » Sat Mar 28, 2026 5:03 pm
Hello from Barcelona! I had a problem: reverse gear engaged fine (MT 82), but the taillights didn't come on, and there was no engagement sound, even with a new switch. The solution was to grind down the switch by 1 mm with a grinding disc, achieving enough depth for the mechanism to make contact with the switch. Now everything works perfectly. Cheers!
chalo73
Users browsing this forum: jaaa1976, vansit1
