Mk 7 - Heater (A/C) version - no heat, vacuum ok
Re: Mk 7 - Heater (A/C) version - no heat, vacuum ok
Postby Jp71 » Sun Mar 29, 2026 2:53 am
andz327 wrote:sounds about right, remove water hose and manually open valve from inside the pipe and put back on and try it for heat
Appears the valve is operating ok, took it off and the control actuator arm thingy changes the flow of water when I push it in manually. Seems there might be some heat passing through the pipes into the heater matrix when the vacuum is unplugged and the control arm is out but that doesnt translate to heat at the vents (nor when i twist the heat control dial does the control arm move in or out)
COnfusing!!
2007 2.4t dci
140T350
Jp71
Postby Airthies » Sun Mar 29, 2026 9:10 am
Heat inside the vehicle is controlled by the blend door actuator. (On the side of the heater unit accessed from the passenger doorbell)
Solenoid, without checking, I think is controlled by the selection of AC on/off and temp dial position.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Tue Mar 31, 2026 8:49 pm
be prepared for a shock when you see price of the blend door actuator, and they're like hens teeth trying to get second hand , there is a similar one in vw sharan /ford galaxy if you swap over the bit that turns
had to make a manual gizmo for a pals van and used old fashioned choke cable that locks when twisted instead of the actuator motor, was supposed to be until he found a used part but ended not bothering as the choke cable worked good enough and he was happy as cable only cost £9 lol
andz327
Postby Altransit » Tue Mar 31, 2026 9:18 pm
andz327 wrote:be prepared for a shock when you see price of the blend door actuator, and they're like hens teeth trying to get second hand , there is a similar one in vw sharan /ford galaxy if you swap over the bit that turns
Many moons ago, I'm sure that someone on here found that the motor from something else (maybe VW Golf, or maybe it was the Sharan?) could be modded and used instead of the genuine item. It was one of our regulars at the time, but I'm struggling to remember who :roll: :P
I will attempt to find out, wish me luck :lol:
Postby Altransit » Tue Mar 31, 2026 9:45 pm
I can't find the one I'm looking for, but I did find this rather amusing missive from our late great BJT regarding the servo motor :lol:
viewtopic.php?f=5&t=163776&hilit=heater+servo
Postby metalworker0 » Tue Mar 31, 2026 10:30 pm
Altransit wrote:I can't find the one I'm looking for, but I did find this rather amusing missive from our late great BJT regarding the servo motor :lol:
WOW - he reminds me of MR Tweed of Tweeds garage -- youtube
also has handle bar mustache, also has imaginary friend, called Jenkins.
https://www.youtube.com/@TweedsGarage
This guy Deserves more followers, his videos are excellent.
All the best.mark
Postby Airthies » Tue Mar 31, 2026 10:41 pm
The legend BJT at his best.
Gone but not forgotten, what a gent.
"What" being the operative word
V86+patch
V86.04
X-Prog
C81
Airthies
Postby knobby1 » Wed Apr 01, 2026 3:47 am
And our late great BJT is the source of my "Lord Knobrot" moniker..!
Gone but not forgotten.
Lord Knobrot (Smithy)
Postby andz327 » Wed Apr 01, 2026 12:17 pm
seems to be loads for mk7 on ebay, new and at much cheapness
andz327
Postby Airthies » Wed Apr 01, 2026 10:08 pm
andz327 wrote:seems to be loads for mk7 on ebay, new and at much cheapness
Boodyell, nice due diligence there my friend.
Last time I got one, new was over a £100 if I mind right and second hand was about £50 by the time it was delivered.
Ka'ching Ka'ching eBay here we come
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Jp71 » Mon Apr 06, 2026 4:34 am
Airthies wrote:Heat inside the vehicle is controlled by the blend door actuator. (On the side of the heater unit accessed from the passenger doorbell)
I’ve taken the footwell covers off this long weekend. In the photo below the actuator arm doesn’t move when I turn the heat dial with engine on or off. It’s not the screen/cabin/footwell cable as that moves via another cable when I twist that dial. I’m presuming this arm should move to control the temp so my next consideration is whether the blend door is buggered or the solenoid (or both, or something else).
I think I read somewhere this blend door is electronically controlled in the AC version so maybe that arm is controlled by the blend door box and not the other way around.
Happy for all thoughts, comments and suggestions. Cheers
2007 2.4t dci
140T350
Jp71
Postby metalworker0 » Mon Apr 06, 2026 1:38 pm
Seems to be be two types of AC .. one with manual control one with motorised controls , you have the manual one ..
if you look at ebay and look at mk7 ac controls , you'll see ones with the centre dial having a plastic gear operated cable pull system
https://i.ebayimg.com/images/g/SDUAAeSw ... -l960.webp
so i think you'll be pulling out the heater control panel and seeing what's bust .. whats going on... what needs re-attaching or what screw needs tightening or what needs adjustment
all trhe best.mark
Postby Airthies » Mon Apr 06, 2026 2:29 pm
metalworker0 wrote:Seems to be be two types of AC .. one with manual control one with motorised controls , you have the manual one ..
all trhe best.mark
There are two kinds of heater controls on a Mk7.
One is for vans with AC and one for non AC.
Manual AC refers to the fact it is just a fan, a water valve and windows. And this has a manual set of controls with 2 cable controls
Vans with climate control AC have a pressurised condenser system and have a control with only a single cable.
His will have a single cable.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby metalworker0 » Mon Apr 06, 2026 5:10 pm
All i could go on was the catcar site .. one page with manual non ac
the other pages decribed "manual AC" or "automatic AC" and a lots of links .. and as far as i got , just too many to know what was what
Postby Airthies » Mon Apr 06, 2026 5:17 pm
metalworker0 wrote:All i could go on was the catcar site .. one page with manual non ac
So why do you persist in posting info you don't know or can't coroberate?
V86+patch
V86.04
X-Prog
C81
Airthies
