Mk7 euro 5 rwd 2.2tdci won't idle or rev
Postby Jtransit19 » Sat Mar 28, 2026 11:43 pm
Last go on the transhit...
So far ive done:
●injector seals (heads brand new dont need to recut i dont think)
●scv
●fpv
●fuel filter
●lift pump 7-10psi
●3 new crank sensors
●cam and crank in sync
●new head and head gasket
●all new timing chain and guides sprockets etc
(In time)
●leak off test seems fine although cant run it for long enough had to keep starting it over and over again.
●2 new battery's
●new key barrel
●engine rebuilt at 30k wasn't me
●new injectors at 30k continental
●reset every adaptions possible with pcm and tried disconnecting battery's.
●today just tried swapping injectors around and recoding obviously new washers and bolts genuine ones.
●battery low in the video but still started and is the same with a fully charged battery just crankshaft quicker.
● compression test come back at 20 bar
So the van has been running absolutely fine! But i had started the van without the maf plugged in i didn't remeber to plug it in... since then it will not idle nor will it rev. Ive done all fuel related things to it once it started acting like this. It's chucks out a lot of black smoke and f**king stinks. It once had a code when this started about the low pressure side but cleared and has never come back.
Only thing left to do which is compression test it but it was running absolutely fine no hard starts nothing. Or replace injectors but theyre £800 quid and also leak off test said they was fine. Or the hpfp but how would I test it with it being such high pressure and these dont normally go do they? It was all torqued and drop of locktite when doing timing chain.
There's no codes or faults coming up on forscan only thing I can see that I dont like is the frp is low. Ive even tried it disconnecting the frps and it said 28-30k psi but still the same story. I dont think it actually started thinking about it.
Does anyone have anymore advice at all as the van is virtually rust free (rare) and I just dont have the money to m57 swap it yet. Nor would i ever put another 2.2 in it. Euro4 are way better then this euro5 shite my old mk7 has no engine issues at all at 170k.
Cheers guys hope i can get this sorted so I can stop driving a vivaro.
Jtransit19
Re: Mk7 euro 5 rwd 2.2tdci won't idle or rev
Postby tranmx2 » Sun Mar 29, 2026 10:34 pm
E5 does not have an SCV.
3 new crank sensors - Why 3? There is only one.
Recoding - no coding required with the Continental.
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP. Siemens Continental fuel system.
OBD2 ELM 327 FTDI Forscan 2.3.46
tranmx2
Postby Jtransit19 » Sun Mar 29, 2026 10:41 pm
It does have a scv
I tried 3 different sensors as dual mass chewed 1 up then changed to solid
And they do
Jtransit19
Postby gt_addict » Sun Mar 29, 2026 11:16 pm
Sounds like you have covered a fair few things. Since it started with the MAF have you tried swapping it for a known good one? Checked wiring and the pins on the plug?
Because its not idling or revving maybe it hasn’t had time to register all readings before throwing codes for things. Just a theory of course.
gt_addict
Postby Jtransit19 » Sun Mar 29, 2026 11:17 pm
gt_addict wrote:Sounds like you have covered a fair few things. Since it started with the MAF have you tried swapping it for a known good one? Checked wiring and the pins on the plug?
Yes checked it all and another maf they both read 0.6lb on idle or the 2 seconds of idle which should be the standard amount I believe
Jtransit19
Postby tranmx2 » Sun Mar 29, 2026 11:47 pm
Jtransit19 wrote:It does have a scv
And they do
Unlikely to be an E5.
What is the year of manufacture?
maf they both read 0.6lb. MAF is flow not weight.
tranmx2
Postby Jtransit19 » Sun Mar 29, 2026 11:56 pm
And they do
It had a dpf its 2013 with the newer style fuel filter housing and a i tank lift pump
That's what forscan said
Jtransit19
Postby tranmx2 » Mon Mar 30, 2026 12:24 am
E5 2011 to 2014 - some of your comments do not apply to an E5.
tranmx2
Postby Jtransit19 » Mon Mar 30, 2026 12:26 am
tranmx2 wrote:It had a dpf its 2013 with the newer style fuel filter housing and a i tank lift pump
Like??
Jtransit19
