Mk7 2.4 transit hot start problem
Re: Mk7 2.4 transit hot start problem
Postby knobby1 » Mon Mar 30, 2026 7:44 pm
Kopon wrote:Without wishing to be pedantic and I know you generally don't do typos :) but my understanding of the sequence would be that the air ingress must be UPstream of the filter?
"Upstream" would be towards the tank from the filter....fuel flows from tank to filter to pump...anything between filter and pump/injectors will be "downstream" of the filter. Just imagine the flow of the fuel...the source is the tank...which is upstream of everything else...last in the line would be the injectors which is downstream.
Lord Knobrot (Smithy)
Postby Kopon » Tue Mar 31, 2026 1:42 am
Aah right!
Of course when the fuel is running back to the tank then it's the other way round! :D.
I'm actually thinking of trying to simulate the process with a brake bleeding kit I have somewhere around which is a similar configuration.
But not today or tomorrow. I'm concentrating on the high FRP issue for the time being which should maybe be a different thread? I've already been accused of hijacking a thread and I wouldn't want to hurt anyone's feelings :( .
2010 2.4L RWD 140 T330S Cherrypicker
Kopon
