Transit mk6 2.4 diesel starting issues
Postby hodgy » Sat Apr 04, 2026 8:13 pm
Hi im after some advice on possible issues with my recovery truck.it starts then cuts out.it started playing up 6 months ago when one day i was out in it and turned it off and 20 minutes later wouldnt start,eventually got it it started after about three quarters of an hour after that it was ok for 4.months then it started playing up again,sometimes it would start up straight away then other times take a lot of turning over then stopping then the same trying for about half hour.now all it does is start then cut out straight away.no diagnosis done on it just after some possible issues as havig trouble getting someone with forscan or other equipment that can check it over.any help would be appreciated.thanks
hodgy
Re: Transit mk6 2.4 diesel starting issues
Postby knobby1 » Sat Apr 04, 2026 9:58 pm
hodgy wrote:Hi im after some advice on possible issues with my recovery truck.it starts then cuts out.it started playing up 6 months ago when one day i was out in it and turned it off and 20 minutes later wouldnt start,eventually got it it started after about three quarters of an hour after that it was ok for 4.months then it started playing up again,sometimes it would start up straight away then other times take a lot of turning over then stopping then the same trying for about half hour.now all it does is start then cut out straight away.no diagnosis done on it just after some possible issues as havig trouble getting someone with forscan or other equipment that can check it over.any help would be appreciated.thanks
Get Forscan and do it yourself, it's free to download and the cable is cheap. Is the glow plug light flashing..?? The cost of getting it plugged in just once is several times the cost of the cable.
Could be a multitude of things...We'd be guessing and guessing is pointless.
Is the fuel filter still full after sitting for several hours or overnight..??
Lord Knobrot (Smithy)
Postby hodgy » Sat Apr 04, 2026 10:16 pm
No flashing glow plug light,filters full,what would the lead be that I'd need and what would I connect it too,I'm not after people guessing what's wrong just any possible solutions or similar issues they've had and been rectified
hodgy
Postby knobby1 » Sat Apr 04, 2026 10:47 pm
hodgy wrote:No flashing glow plug light,filters full,what would the lead be that I'd need and what would I connect it too,I'm not after people guessing what's wrong just any possible solutions or similar issues they've had and been rectified
Go here and you'll get all the Forscan info you need.
https://forscan.org/download.html
Get the "V-Linker" cable and you'll be golden.
Download Forscan to a lappy, connect cable to the OBD-II port...although the Mk6 is "not" OBD-II compliant... which is why most OBD-II readers won't work on the Mk6.
Postby hodgy » Sun Apr 05, 2026 9:31 am
Thanks for the help might be a daft question but would the laptop need to be connected to the Internet
hodgy
Postby Altransit » Sun Apr 05, 2026 10:28 am
hodgy wrote:Thanks for the help might be a daft question but would the laptop need to be connected to the Internet
You would need to download the Forscan program onto the laptop from the internet, but the lappy doesn't need to be connected to the 'net when doing the readings in the van :)
Postby hodgy » Sun Apr 05, 2026 11:07 am
Thanks I'll give it a try
hodgy
Postby blfmtriv » Fri May 29, 2026 11:06 pm
hodgy, did you find the solution to your starting issue?, please share if so.
thanks Drew
blfmtriv
Postby hodgy » Sun Jul 05, 2026 7:23 pm
Sorry for the late reply not been well but no still have the same issue any thoughts thanks
hodgy
