Gearbox code difference
Postby Goldylox » Mon Feb 16, 2026 9:59 pm
Hi there, my gearbox blew up from my Transit based hymer .
The former owner replaced the engine with a 2.5TD from a transit from 1993 so a MK4
Now, the gearbox code on the one i have is 88VT-7006-AA and now i’ve found one which they have done up but has the code 88VT-7006-AB
So what would be the difference with the AA or the AB version?
I’m based in Holland and the parts are harder to find .
I’ve seen gearboxes with the same code but then they would have to come from Poland , Estonia France or Spain and then i dont know what i’m getting .
The one in Holland is refurbished but annoyingly with AB on the end instead of AA
Can someone help me please .
Want to get my camper back
Goldylox
Re: Gearbox code difference
Postby Altransit » Tue Feb 17, 2026 12:20 am
So far as I'm aware, those last two letters are updates on the original numbers, therefore AB is an update to AA, and AC would be a later version again etc.
Postby Goldylox » Tue Feb 17, 2026 6:25 am
Thank you for your quick answer.
Goldylox
Postby Goldylox » Mon Apr 20, 2026 9:35 pm
So I have changed my gearbox even though it had the last two digits different .
Works well but does leak still a bit .
I guess the gearbox oil is very thin and they did fill it up to the brim.
Goldylox
Postby knobby1 » Tue Apr 21, 2026 12:46 am
Goldylox wrote:So I have changed my gearbox even though it had the last two digits different .
Oil shouldn't be too thin, it should be 75W80 gear oil.
Lord Knobrot (Smithy)
Postby Goldylox » Tue Apr 21, 2026 12:25 pm
I used the Kroon-oil SP1031 made for these gearboxes .
Goldylox
Postby knobby1 » Tue Apr 21, 2026 8:11 pm
Goldylox wrote:I used the Kroon-oil SP1031 made for these gearboxes .
The Ford spec for the oil is WSD-M2C200-C which is basically 75W90/75W80 GL4 Synthetic.
I use Redline 75W90 in mine.
