Brake issue
Brake issue
Postby Dweeb » Sat Apr 25, 2026 3:18 pm
Hi, very new to this forum but I am at my whit's end. I have a 2017 ecoblue automatic and have recently changed the brake pads and one calliper on the rear brakes, this does not have electronic brakes just a standard handbrake. I finished the job and now the van won't start, says there is a brake issue. I have bled the brakes, put new pads and sensors on, tried to reset the computer by taking off the negative terminal from the battery and nothing works. Can any one help with advice please as I can't even take it to a garage to look at the problem
Dweeb
Re: Brake issue
Postby metalworker0 » Sun Apr 26, 2026 3:05 pm
There is a set procedure to put it into maintenance mode for changing pads and put it out of maibntence mode.
google
How to reset electronic handbrake on ford transit
Re: Brake issue
Postby knobby1 » Sun Apr 26, 2026 7:46 pm
Dweeb wrote:Hi, very new to this forum but I am at my whit's end. I have a 2017 ecoblue automatic and have recently changed the brake pads and one calliper on the rear brakes, this does not have electronic brakes just a standard handbrake. I finished the job and now the van won't start, says there is a brake issue. I have bled the brakes, put new pads and sensors on, tried to reset the computer by taking off the negative terminal from the battery and nothing works. Can any one help with advice please as I can't even take it to a garage to look at the problem
Disconnecting the battery in an attempt to "reset the computer" does absolutely nothing except require you to reset the clock.
Lord Knobrot (Smithy)
