ECU test and repair recommendations
Postby bun7575 » Mon Apr 27, 2026 6:34 am
Hi guys so I'm pretty much decided that my ECU is toast but I would like to get it verified and then repaired.
Can anyone suggest a place that's good preferably specializing in transits that will bench test my ECU?
Don't want to get stung!!!
bun7575
Re: ECU test and repair recommendations
Postby Airthies » Mon Apr 27, 2026 8:05 am
Cheaper to get a second hand one and fire that in.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby metalworker0 » Mon Apr 27, 2026 3:11 pm
there have been cases of the Power Control Module (PCM) getting water in the multiplug and inside the PCM..
ECU -- is electronic control module -- is a general term that may get people mixed up with other modules.
so work checking that before you spend the dosh
