Thermostat to egr hose
Postby Parky7 » Tue May 05, 2026 7:18 pm
Hi Chaps
2010 - 2.4 - 100/350
Can anyone point me in the right direction…
After a thermostat to egr hose , tried google but comes up with loads of them… catcar never seems to work for me…
Hose split and had to be recovered of the motorway (you’ve got to love a smart motorway)
Regards
Parky
2010 - MK7 100/350 LWB Hi-Top
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Re: Thermostat to egr hose
Postby metalworker0 » Tue May 05, 2026 7:46 pm
here the cat car page
http://www.catcar.info/ford/?lang=en&l= ... EzNQ%3D%3D
like i dont know what you have, loads of i-options for that hose , rear heater , climate control , auxiliary heater , roof mounted heater , loads of choices to make
Postby Parky7 » Tue May 05, 2026 7:57 pm
Hi
Thanks for the info ,
Think is either
9Y438A or 9Y438B
Will have to get under and take it off
Parky
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby knobby1 » Tue May 05, 2026 8:02 pm
Parky7 wrote:Hi
Think is either
9Y438A or 9Y438B
Parky
Are you after the hose to the EGR cooler or EGR valve..??
It's actually pretty simple, do you have a fuel burning auxilliary heater, rear seat climate control, rear compartment heating or not..??
Lord Knobrot (Smithy)
Postby andz327 » Tue May 05, 2026 9:24 pm
knobby1 wrote:
Parky7 wrote:Hi
Think is either
9Y438A or 9Y438B
Parky
wrong side of the bed again ma laird
andz327
Postby metalworker0 » Tue May 05, 2026 9:31 pm
Parky7 wrote:Hi
Think is either
9Y438A or 9Y438B
Parky
just to mention - they are not the part numbers // the part number is the 7 digit code to the right of them.
Postby DanMK7uk » Tue May 05, 2026 10:20 pm
Cut hose either side and put some copper tube between and some hose clamps. Repair before replacement. Save money save time. “Save the planet” yeah right lol
DanMK7uk
Postby Parky7 » Sat May 09, 2026 9:15 am
Sorry for the late reply, been away for a couple of days…
I haven’t had a look yet
All I know so far after a quick visual inspection is that it’s the hose from the thermostat housing going towards the egr , it has a big split in it…
No no rear heater
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby metalworker0 » Sat May 09, 2026 3:01 pm
link in the second post down, there are a lot of choices, you only mentioned that there no rear heater choice .. there is more to it than that like AC or not choice etc
You choose the one you are sure about.
You then pick the 7 digit part number out
Put it into ebay
Decide what you want - pick from the ebay results - the results will contain, genuine ford , aftermarket well known brand , or cheap unknown brand. you look at the pictures of it and decide if its the exact same one - you press buy.
Or you go to a ford dealer .. give them the reg number and they will sell you the exact one .
That's as far as i can help
Postby Parky7 » Thu May 14, 2026 7:33 am
Once again thanks and sorry for the slow reply, working away at the moment…
No air con , just a basic old girl.
Will try and take a look weekend.
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby Parky7 » Sun May 31, 2026 7:43 pm
Finally got around to having a look today…
Thermostat to egr valve had burst , temporarily joined together with a 22mm copper pipe , van seems to run ok ,
Still a bit of pressure in the coolant tank when cold and coolant looks a bit dirty, I don’t think it’s head gasket or at least I hope it’s not…
The small egr valve to cooler pipe looks a bit blisterd as well also looks a bit wet on top of the gearbox…
I possibly think it is egr cooler related as these do corrode inside and. Allow coolant and exhaust gases to mix , so have ordered a new cooler, gaskets and new hoses as this is the cheaper option for starters.
They should turn up this week and I have a day off Friday so will fit all this and hopefully it fixes the problem.
Like I said van is running fine without any hesitation or loss of power,
Did fit a new oil cooler last year so that should be ok…
Parky
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby knobby1 » Sun May 31, 2026 7:46 pm
Parky7 wrote:I possibly think it is egr cooler related as these do corrode inside and. Allow coolant and exhaust gases to mix , so have ordered a new cooler, gaskets and new hoses as this is the cheaper option for starters.
They should turn up this week and I have a day off Friday so will fit all this and hopefully it fixes the problem.Parky
Pig of a thing to get at, runs around the back of the cyl head.
Postby Parky7 » Mon Jun 01, 2026 8:12 am
Yes
Did have a quick look where it is , :shock: so should be fun with plenty of swearing going on…
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby Parky7 » Sun Jun 21, 2026 9:31 pm
Evening chaps
Right egr cooler changed plus all relevant pipes replaced…
Not losing coolant now but getting lots of pressure in the expansion tank and hard hoses the next morning…
Also the top rad hose is hot , bottom rad hose is cool
Heater is working
Van not overheating at least according to the gauge (haven’t monitored it over forscan)
A couple of sniff tests were negative
No smoke or mayonnaise in the oil
Runs very well but does smell hot after a long run
Had new viscous last year but not 100% sure it’s working as it should
Anything else I can try before the I have to take the head off
Maybe thermostat, would that cause excess pressure
Parky
V-Strom 650
KTM 390
Yamaha XSR 700
Parky7
Postby metalworker0 » Sun Jun 21, 2026 10:17 pm
if the hoses are hard in the morning .. without even starting it .. i think the head gasket has gone. usually any excess pressure from the day before should go, as the coolant cools down.
Other tests are:
Cooling system pressure tester - inflate to 15 psi .. see it it holds,, and see if pressure builds too quickly.
A boroscope used whilst it's under pressure from the tester, to see leaks into cylinder.
Leak down tester to see leaks between each cylinder,
All would be easy if petrol. but not diesel.
But think you've got a headgasket blow that is acting like a one way valve into the water jacket .. for the pressure to hold like that until the next morning.
Quick test .. first thing in the morning on cold engine .. rubber glove on expansion tank- rubber bands to hold it .. if it inflated within 1 min of cold start .. then it's the head gasket.
if it had oil cooler issues then oil will be in the header tank.
I don't know why the coolant combustion tester isn't working, if like what you've described
cron
