mk7 2.2 rwd injector nightmare
Re: mk7 2.2 rwd injector nightmare
Postby BHM » Thu May 07, 2026 7:08 pm
Tsp_main wrote:https://youtube.com/shorts/-oGlY-j1DwU?si=AZ1imaWfjy-60I1z
Thats a link to a clip of it
Got it out yet?
BHM
BHM
Postby Tsp_main » Thu May 07, 2026 9:03 pm
I just got it out this evening after a few more hours faffing. I will attach some pics. I will upload a video of the tip. Whats your guys opinions. Looks to have got v hot to me
Tsp_main
Postby Tsp_main » Thu May 07, 2026 9:04 pm
Another pic
Tsp_main
Postby knobby1 » Thu May 07, 2026 9:24 pm
Tsp_main wrote:Another pic
Typical result of suspected water in fuel..
Lord Knobrot (Smithy)
Postby Tsp_main » Thu May 07, 2026 10:16 pm
Thanks mate, going to remove the seals and recut the seat try a new injector/injectors( get my others tested). She how it goes. First I've seen it like that I suppose you learn something new everyday. Hoping thers no major damage to the cylinder head.
Tsp_main
Postby Airthies » Thu May 07, 2026 10:16 pm
Wot hee said.
Get them tested before putting any back into the engine
Do a tank drain, clean and flush all lines and replace Fuel filter.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Tsp_main » Thu May 07, 2026 10:29 pm
Wot hee said.
Will do 100%. Need to order a rocker cover anyway as I smashed the old one away.
Tsp_main
Postby Tsp_main » Sat May 16, 2026 5:11 pm
So as a follow on from this, i picked up an whole low milage donor engine locally, looks to have blown out the core plugs beside the injector holes. Where is the best place to get replacements. As this engine is low milage and clean with new injecots. Like to get it cleaned up and ran.
Tsp_main
Postby Airthies » Sun May 17, 2026 12:04 am
Tsp_main wrote:So as a follow on from this, i picked up an whole low milage donor engine locally, looks to have blown out the core plugs beside the injector holes. Where is the best place to get replacements. As this engine is low milage and clean with new injecots. Like to get it cleaned up and ran.
Ford parts plus or an engine rebuilder.
Used to be able to get stuff like that from any motor factors or general automotive hardware suppliers but gone are those days.
I'd be asking why have those plugs have been forced out.
Possibly do a "bench run" compression test before fitting.
Also a good reason to swap out the glow plugs before fitting.
V86+patch
V86.04
X-Prog
C81
Airthies
