Wanted: 844F 6A616 AA oil pressure relief valve 1985 Ford
Postby Garcia66 » Tue May 12, 2026 1:14 pm
Hi everyone,
I’m looking for the engine oil pressure relief / oil system valve assembly for my father’s:
Ford Transit Mk2 100
Year: 1985
Body: Van / Furgón
Engine: 2.5 DI Diesel
Engine type/code: D / 4AB
Engine size: 2496 cc
The part itself is stamped with the Ford reference: 844F 6A616 AA
I have attached photos showing:
- the complete valve assembly,
- the body, internal plunger/piston and spring,
- and a close-up of the stamped part number.
We are trying to find either:
this exact part, or a confirmed compatible replacement.
Does anyone have one available, know of a supplier, or know whether this part was used on other Ford Transit 2.5 DI engines as well?
Any help would be greatly appreciated.
Thanks very much!
Garcia66
Re: Wanted: 844F 6A616 AA oil pressure relief valve 1985 For
Postby metalworker0 » Tue May 12, 2026 5:11 pm
I can tell you its 7 digit ford part number, which is 6141432
and cant be found
suggest you go down the LDV parts catalogue route
find a model with your engine in it .. and go from there
as all ford parts catalogues we use only start at 1991 or so
but ... they have the 2.5 in a 1991 transit
so look here ... you are after the 7 digit part number
http://www.catcar.info/ford/?lang=en&l= ... FJQg%3D%3D
Return to Mk 1 & 2
