Ford Says No Exhaust Gasket???
Postby MinOMins » Tue May 12, 2026 9:49 am
Mk7 2010, FWD, 2.2, SRFA.
Hello, I'm replacing the silencer and I contacted Ford for the gasket part number between the cat and silencer.
Ford says no gasket it's metal to metal?
I was thinking that may be alright brand new from the factory, but I have my doubts about it sealing properly.
Anybody have experience of this, would you use sealer, a gasket or go metal to metal?
MinOMins
Re: Ford Says No Exhaust Gasket???
Postby knobby1 » Tue May 12, 2026 10:22 am
Stewarty1 wrote:Mk7 2010, FWD, 2.2, SRFA.
No gasket is correct.
https://www.catcar.info/ford/?lang=en&l ... OSsxMzM%3D
Lord Knobrot (Smithy)
Postby MinOMins » Tue May 12, 2026 2:30 pm
Thanks for the reply Knobby1
Ok. As I understand it then, the surfaces are machined precisely enough for a clean mating and therefore no leaks.
That saves a little bit more money :D
Thanks again and all the best.
MinOMins
Postby metalworker0 » Tue May 12, 2026 2:47 pm
you could try and exhaust and tyre depot place they may have one
Postby MinOMins » Tue May 12, 2026 5:23 pm
metalworker0 wrote:you could try and exhaust and tyre depot place they may have one
Thanks Mark.
Good idea mate I think I'll get a gasket.
The van has the original cat and box on it. Both flanges are quite perished after UK salt roads and 160k on the clock...
It's done well after 16 years, but I think it prudent as the box will obviously have a new flange on it but the cat will still be old. I will research the gasket situation to see if there is one available somewhere.
Thanks again :D
MinOMins
Postby MinOMins » Wed May 13, 2026 9:08 am
Found this gasket, Genuine Ford Transit MK7 Exhaust Gasket 1754007. Listed by PartsPlus as being correct for my vehicle.
Well there you go then!
Thanks for the help :D
MinOMins
Postby knobby1 » Wed May 13, 2026 8:06 pm
Stewarty1 wrote:Found this gasket, Genuine Ford Transit MK7 Exhaust Gasket 1754007. Listed by PartsPlus as being correct for my vehicle.
That Pn: 1754007 gasket is listed for Euro-5 only, (Sept 2011> the end of 2014).....yours is 2010 Euro-4.
It may fit though.
Postby MinOMins » Wed May 13, 2026 9:15 pm
It may fit though.
Found this,https://www.ebay.co.uk/itm/188076926928 on eBay and at £9.90 I figured it would be worth a try. I have the option to return it.
On page 15 of the compatibility list it states fitment is suitable.
Ford Transit 2010 Diesel Bus 2.2 TDCi FWD -- FD_ _,FB_ _,FS_ _,FZ_ _,FC_ _ 2198cc 85KW 115HP SRFA;SRFB;SRFC;SRFD;SRFE
Now it looks like I got the last one... :D
MinOMins
