Mk6 2.0 tdci engine query advice needed
Postby trannyfreak » Thu May 14, 2026 11:45 pm
Hi all, im wanting to swap engines in my swb mk6 2005 transit, 2.0 tdci, I brought an engine from a bloke off the Internet a 2.0 tdci he said its from a 2006 transit converted camper done 84k, but when I recieved it today its totally different looking to mine, will this fit? Ive added pics of my engine and the new one, have I been conned? Many thanks
trannyfreak
Re: Mk6 2.0 tdci engine query advice needed
Postby Stevelien » Mon May 18, 2026 10:41 am
The new one is missing the intake. The EGR might also be the new front-mounted type; I can't tell from this. You should take into account that at some point short injectors were fitted to 2.0 TDCI engines (Mondeos); those blocks can only be swapped using the original ECU. The short 2006 FIFA injector type engine ECU does not work with the long injector type FIFA 2005 engine ECU.
Stevelien
