Transit lower swivel replacement
Postby spainish steve » Wed May 20, 2026 8:19 pm
Hi 2008 mk7 front wheel drive transit what sort of job is it to replace the front lower swivels cheers in advance
spainish steve
Re: Transit lower swivel replacement
Postby metalworker0 » Wed May 20, 2026 8:54 pm
WELL 18 years old says it may not be easy
And unlike the mk6, you have a couple of extra things with the ball joint, as some of them don't come with these extra bits so buy this one or one like it with the extra stuff .. plate and spare bolts as i thinking the plate will not be in very good condition .. look at it on the van before and decide
https://www.ebay.co.uk/itm/286738821829?
There are kits for pushing it out and installing it.
Other people will take the whole knuckle off and use a hydraulic press
Yes. people have struggled with the kits and walloping it with hammer .. lots of posts here with people doing the struggling/
but they have NOT struggled with a press ... if you have the room---- a must buy .. in my opinion
20 toners on ebay at £125... they have never been so cheap!
Postby andz327 » Fri May 22, 2026 9:50 am
ACTUALLY IT IS LIKE A MK6 and that's not it but this is
https://ebay.us/m/yKY73D
andz327
Postby metalworker0 » Fri May 22, 2026 10:23 am
i dont know .. says mk7 on that type on a few ebay listings .. presumed they come with the extra bits or not
Postby knobby1 » Fri May 22, 2026 9:53 pm
metalworker0 wrote:i dont know .. says mk7 on that type on a few ebay listings .. presumed they come with the extra bits or not
There are two types of lower wishbones, normal for single rear wheel and heavy duty for the twin rear wheel machines...ball joints are different part numbers for each too.
Lord Knobrot (Smithy)
Postby andz327 » Sat May 23, 2026 2:17 pm
its a FWD
andz327
Postby metalworker0 » Sat May 23, 2026 3:00 pm
what's even more confusing with ebay
is .
if you put that part number into the search ... - 1417351
2100 results and no mention of FWD or RWD, well not in the first three pages, which is all i checked
and ford on ebay want £219 for it
some results say; heavy duty version
Postby bortaf » Sat May 23, 2026 4:41 pm
IIRC the H/D balljoints are the same as Mk1 connect :?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby knobby1 » Sat May 23, 2026 9:40 pm
andz327 wrote:its a FWD Sent from my SM-G990B using Tapatalk
FWD and single rear wheel RWD are the same.
Postby metalworker0 » Sat May 23, 2026 9:47 pm
in answer to Bortaf ---Not on my mk1
the shield (cover) does not have two bolts in it, it just pushes over it ... this shield is there to stop the heat from the disc burning the rubber boot. and if its rotted away your new ball joints will not last long
when i bought these shields , it took some looking to find, just looked at my email they were £14.99 (in year 2024) each and genuine ford and the only ones listed on ebay.
now you have maybe 10 listed ,note only one with ford logo ebay seller .. and cheaper than the rest .. as some are over £50.
in catcar info .. mk7 only illustrates the two bolt shield design .. the mk6 shows it without the two bolt shield . unlike the connect, no cover / shields in the diagram for mk6... although .. in sure yesterday when looking at ebay, i seen a ball joint with the "connect type" shield included with a ball joint for the mk6/7 transit
Postby andz327 » Sun May 24, 2026 2:52 am
and the ball joint with the two bolt holes still isn't For mk7 fwd ffs
off on another tangent i received a wee brake pipe tool today
£36 worth and well worth it
(just thought I'd share that)
andz327
Postby knobby1 » Sun May 24, 2026 4:13 am
andz327 wrote:and the ball joint with the two bolt holes still isn't For mk7 fwd ffs
My Single rear wheel RWD doesn't have two bolts holding the lower ball joint on...and is the same Part number as the FWD.
Postby andz327 » Sun May 24, 2026 11:28 am
WORD OF WARNING TO THE OP... DONT TAKE ANY MEAT OFF THE KNUCKLE WITH ANY TYPE OF FILE ,SANDING DISCS OR STONE GRINDERS TO MAKE FITTING EASIER OR YOUR NEW BALL JOINT WILL KEEP FALLING OUT AND THE CIRCLIP WONT HOLD IT IN FOR LONG ON THE ROAD.
MA LAIRD I've never seen a mk7 with a 2 bolt ball joint but they could certainly do with them , was working on a 2014 custom couple weeks ago which had similar ball joint to the mk7 but the knuckle had extra meat on it same shape as bolted ball joint and you would be able to drill and tap to suit the 2 bolt item if pin was correct shape and thickness
andz327
Postby bortaf » Sun May 24, 2026 7:40 pm
metalworker0 wrote:in answer to Bortaf ---Not on my mk1
just been out and checked both my 53 plate connect and my 07 430 ambulance have the same LBJ, unshielded with circlip :wink:
i wonder what spec dictates which is ftted ?, TBH i'm not a prolific transit mechanic (not for a good few years now) but i've never changed the shielded type, never come accross one and i've done FWD, RWD, SRW and DRW so i wonder what the spec is to have them :?
Current fleet
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby metalworker0 » Sun May 24, 2026 8:13 pm
Mine is the 2006 base model , tddi , 75 ps , no thrills.
Perhaps the Turkish ones and Romanian ones are different or they left off the ruisted remains when they changed the ball joint, because of fords prices or not available
Mine was made in Turkey
