Non Sync to SYNC 2.5 Upgrade, with part numbers - completed!
Re: Non Sync to SYNC 2.5 Upgrade, with part numbers - comple
Postby Altransit » Thu Jan 08, 2026 8:30 pm
Mark10evo wrote:I’ve tried to have you got it mate? If not please drop me a message so can reply.
Much appreciated
I don't think you can PM, until you've made a few more posts. Why not ask your questions on this thread :?:
Postby Mark10evo » Thu Jan 08, 2026 8:41 pm
I’m trying to do the same as what you’ve done in this post mate, bought all the stuff you listed above but cans and this stuff really ain’t my strong point haha just needed some extra help if don’t mind? Thank you
Mark10evo
Postby Mark10evo » Thu Jan 08, 2026 9:50 pm
Hopefully that’s ok mate. Just to run a few things by you?
Mark10evo
Postby Mark10evo » Fri Jan 09, 2026 9:54 am
Much appreciated
I just needed bit of help in connecting what to where mate
Mark10evo
Postby mafty » Thu Jan 15, 2026 9:13 pm
Mark10evo wrote:Hi how can I contact you please via email just so can ask a few questions would be massively appreciated mate.
Regards
Feel free to post any further questions on here mate, as I don't always get PM alerts.
Your questions and my answers may be of use to anyone alse doing the conversion. :D
Di! Ecce hora! Uxor mea me necabit!
mafty
Postby tolis85 » Tue Feb 03, 2026 10:27 pm
Hello. I have a 2021 ford transit t350 with the base 4" screen with no sync. Will these mods work on my van? I just need bigger screen for my backup reverse camera.
Thank you
tolis85
Postby mafty » Wed Feb 11, 2026 6:17 pm
tolis85 wrote:Hello. I have a 2021 ford transit t350 with the base 4" screen with no sync. Will these mods work on my van? I just need bigger screen for my backup reverse camera.
Thank you
Yes, that is exactly the unit I had before I changed mine. Follow the instructions and you should be well away. You will need to get a camera adapter though, which just plugs in to the back of the head unit.
Message me if you have any questions, but read through the whole thread first, as there are a few Q and As on there.
Good luck!
mafty
Postby gxyb82 » Sat Mar 07, 2026 6:40 am
Hy! Fordpass not work in my car. Any solution?
gxyb82
Postby Clam76 » Mon Apr 20, 2026 3:43 pm
I have a 2023 Transit equipped with a 4-inch screen, without SYNC or an APIM module... a very basic model :roll: !
If I understood your discussion correctly, does that mean I can install an 8-inch screen and use CarPlay/Android Auto by following your tutorial exactly ?
And without adding the APIM module above the glove compartment ?
Is that right ?
Thank you so much for your great work :D
Clam76
Postby mafty » Wed Apr 29, 2026 8:21 am
Clam76 wrote:I have a 2023 Transit equipped with a 4-inch screen, without SYNC or an APIM module... a very basic model :roll: !
Is that right ?
Yes, you only need the APIM if you fit a SYNC3 model. The Sync 2.5 doesn't have an APIM, so just the head unit, screen and USB port/cables are needed, as in my original post.
Message me if you need any more info.
mafty
Postby Clam76 » Sun May 10, 2026 5:32 pm
THANK YOU SO MUCH ! It works great !
It’s a real pleasure to be able to use Android Auto and CarPlay.
The only thing is that the camera isn’t working anymore.
Maybe I need to add an adapter or adjust some settings ?
Thanks for your help.
You’re doing a truly amazing job. Much better than the local Ford dealership !
Clam76
Postby mafty » Mon May 11, 2026 10:47 am
Clam76 wrote:THANK YOU SO MUCH ! It works great !
Thanks for your kind words. I've found loads of helpful info on here over the years, so I am happy to return the favour.
As for your camera, I don't know. I fitted an aftermarket camera myself, and had to buy an adaptor online, and I had to change the settings in ForScan IIRC, to set it to the non HD option.
Mine works fine now, and displays the ParkPilot in the top right of the screen, as per the genuine camera.
mafty
Postby fowkesy69@gmail.com » Sun May 17, 2026 9:19 pm
Hello,
I have installed 2.5 to my transit with using the Fiesta ACM and Screen, it is working but trying to get my head around the Usb side and apple play. I see we plug the back cable in, does anyone have any photos on what we need to do? Sorry more of a visual learner.
I also have block Errors on 1 and 8, so the Dab doesn't work, so any advice on this. I have tried putting a 2.5 transit as built file on Forscan but doesn't work and tried changing manually also.
Any help really appreciated.
Joe
fowkesy69@gmail.com
Postby mafty » Mon May 25, 2026 9:03 am
fowkesy69@gmail.com wrote:Hello,
Joe
Hi. I don't have any photos, but if you carefully follow the directions in the first post, everything should work fine, assuming you have the correct cables.
Maybe someone else took photos when they did theirs?
mafty
Return to Transit Custom
