A associate of ours had a smoke leak test done at garage and then went away on a holiday.
I was presented with a transit 2018 2.0 which had blocked dpf.
They drove it until it would drive no more, the dpf is full of oil and the turbo has seized.
We have a turbo on order and the engine runs without turbo air and exhaust connections.
So at least engine is OK.
Dpf with endoscope doesn't look collapsed, there is a chalky substance in a ring round the vapouriser mounting point, I presume this is meant to be there? as after grease wiped off its white.
I'm quite surprised at turbo failure at 66k miles it is seized solid, I'm thinking it seems to have blown the oil seal on turbo bearing-so planning on cleaning intercooler and dpf and reassembling with new turbo.
Has anyone had a similar experience please?
