High spec clocks. ??
Postby mjsroofing » Thu May 28, 2026 12:32 pm
2009 transit, lwb, medium roof, 115 ps.
So ive bought a set of high spec clocks, and ive got the bcm to go with it.
Question is, without changing the bcm, will anything work on the new clocks.
I was thinking of fitting the clocks for now and sort bcm out later on. I can also see what the mileage is too then.
Also, has anyone got an instruction manual to program the bcm lol
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Re: High spec clocks. ??
Postby Altransit » Thu May 28, 2026 1:43 pm
Everything that worked on the old clocks will work on the new clocks, they're plug-n-play.
The mileage will be whatever is on the new clocks, it won't correct to whatever is stored in the BCM. I kept a note of my old mileage and asked Vantuner to correct it.
I can't remember what didn't work on the new clocks, on mine, apart from o/s temp which needed the o/s temp sensor, but, nothing that mattered initially, but you'll need the small left hand stalk to zero the (now electronic) tripmeter.
Loot can probably help with BCM programming, as Vantuner did mine 8)
Postby mjsroofing » Thu May 28, 2026 2:30 pm
Altransit wrote:Everything that worked on the old clocks will work on the new clocks, they're plug-n-play.
Thanks.
Im hoping the mileage is less than mine, but the clocks was out of a scrap van so I doubt it.
I have the stalk ready fitted. (Only for the last 10 years lol )
Ill clocks over on weekend and see how it goes.
mjsroofing
Postby mjsroofing » Mon Jun 01, 2026 7:05 pm
Well I fitted the clocks and the extra wires so the stalk works, mileage was 197k , disappointed but was expected.
Just got to get the temp sensor now.
mjsroofing
Users browsing this forum: Google [Bot], gsc1ugs
