Aftermarket Differential Parts Suppliers
Postby snax53 » Thu Jun 04, 2026 7:23 pm
Hi all,
Can anyone tell me if there are any suppliers that offer aftermarket/ uprated differential parts for a drw mk8 transit?
I was looking to replace the carrier complete with gears and ring and pinion .
I an in the UK
Cheers.
snax53
Re: Aftermarket Differential Parts Suppliers
Postby metalworker0 » Fri Jun 05, 2026 8:31 pm
in order to get help with your question from people here .. not me, as i know nothing about what's best. ..only upgrade i know is a "limited slip diff", you need to state FWD or RWD
Postby dumper » Fri Jun 05, 2026 9:13 pm
Double rear wheel has to be rear wheel drive .when I had the crown wheel and pinion ratio changed had to get it from Fords but that was 8 years ago
Postby metalworker0 » Fri Jun 05, 2026 9:39 pm
DWR =Double rear wheel, sorry never come across that one before.
Postby Airthies » Sat Jun 06, 2026 2:11 am
Can I ask why you would like to replace the carrier as well as the crown wheel and pinion?
There's a crowd in the Halifax area that specialise in diff overhaul and replacement gear sets.
https://www.facebook.com/share/17cFDaP3me/
Depending what you intend to use the van for ie: on soft ground and spinning one wheel regularly has caused excessive wear on the spiders and gears?
I can offer ARB diff locks specifically for the Mk8 axle.
If you want more information drop me a message via the AMS4x4 Facebook page
https://www.facebook.com/share/17JY4GYuDy/
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
