2.2 pulsing when cold
Postby coswurv » Sun Nov 03, 2024 10:37 am
Right guys I’ve got a 2015 custom 2.2 155bhp 102k on the clock it’s started to play up a little when starting from cold initially it starts and idles fine but when you start driving it gives like a pulsing/hesitant feel on the throttle around 2k revs and can sound like it has a bit more “diesel knock” to it, once you’ve driven say 2-3 miles and it’s warmed up it goes away and everything is normal until it’s left over night and stone cold again ? I’ve put some injector cleaner through it and just had the glow plugs and egr changed but unfortunately still the same. Just wondered if anyone recognises the symptoms and has any ideas, I’ve included a link from this morning and you can hear it doing at 2k revs when I go up into 3rd any help would be appreciated as to where I go from here with it, one other thing is the colder the weather the longer it can take to go away.
I service the van every 10-12k with all filters and genuine, castrol oil and used premium fuel in it since 6k miles. It uses no oil no water with no leaks and no smoke and you can pull dipstick out when running and up to temp with no smoke or puffing.
https://youtu.be/VR_cyyTD1bI?si=D8seHVE8KIXJfU6A
coswurv
Re: 2.2 pulsing when cold
Postby Radiofence » Wed Jan 01, 2025 11:36 pm
Get your forscan on it. Mine was a bit like this before j changed the intercooler temp sensor. (Woodywoodywood)
Transit custom 2.2
Radiofence
Postby Radiofence » Wed Jan 01, 2025 11:40 pm
HAVE u put forscan on it?
Transit custom 2.2
Radiofence
Postby seb_custom » Mon Feb 17, 2025 2:56 pm
Hi, I’ve got a 2013 Custom 2.2 125bhp with 150 000 km and I might have the same issue as you @coswurv.
I have also a DPF problem (code P02463) so I've watched O'Rileys videos on youtube.
Radiofence wrote:HAVE u put forscan on it?
I've had a look with Forscan, and during a short drive something caught my attention:
the coolant temperature in Forscan (ECT) was still low (between 50°C and 65°C, however the indicator on my dashboard was already at 90°C).
So I'm thinking the intercooler temp sensor might have a problem? Or maybe the hole thermostat...
@Radiofence did you have a false indicated water temp on your dash or in Forscan before you changed the sensor? And can you please indicate where is this sensor located?
seb_custom
Postby Radiofence » Thu Feb 20, 2025 11:26 pm
No I didn't have any water temp warnings. It's a green sensor at the end of the air cooler. Lie under the van and u will c it.
Transit custom 2.2
Radiofence
Postby Jimmyslash » Sun Oct 19, 2025 12:56 pm
seb_custom wrote:Hi, I’ve got a 2013 Custom 2.2 125bhp with 150 000 km and I might have the same issue as you @coswurv.
I have the issue of the temperature reading 90c soon after cold start but the scan tool I use was indicating 40-50c
Did you manage to fix
Jimmyslash
Postby seb_custom » Fri Mar 20, 2026 10:05 pm
Sorry for the delay.
I managed to fix the DPF problem, but the coolant temperature indicator on my dashboard still climb at 90°C really fast (whereas in Forscan ECT is between 50°C and 65°C).
But I think it has always been like this on this van. Maybe it's supposed to be like this from factory...
seb_custom
Postby caspersteve » Sun Jun 07, 2026 8:07 pm
hi all its been a while since my last interaction but my new to me 2015 2.2 has the pulsing/jerking throttle and i just wondered if any one had found the cause
i havent plugged any diagnostic in yet but the van seems to drive fine after a few minuets after running so just wondered what to look for first. thanks in advance for any advice
caspersteve
Return to Transit Custom
