2019 Transit Connect LTD edition 1.5tdci
Postby cricky22@hotmail.com » Mon Jun 15, 2026 4:06 pm
Hi, New to the forum.
I have a strange little noise and was wondering if anyone on here has come across this for this engine model. Is it normal for these engines or anyone any ideas as to the cause or its location? It totally disappears if you add a slight touch to the accelerator say 50rpm, only 49k on the clock
Any opinions greatly appreciated it may be normal i don't know for this engine type. Sorry wouldn't let me add video.
Re: 2019 Transit Connect LTD edition 1.5tdci
Postby cricky22@hotmail.com » Mon Jun 15, 2026 9:25 pm
Any one know how to upload a video of the sound?
Postby metalworker0 » Mon Jun 15, 2026 9:39 pm
You cant here ..
You put it on youtube with a link to the youtube video in your post
Postby cricky22@hotmail.com » Mon Jun 15, 2026 9:47 pm
Thanks Mark
Postby Frag » Sun Jun 21, 2026 5:26 pm
cricky22@hotmail.com wrote:Hi, New to the forum.
Open the bonnet,with it running and making the noise try holding the tube that goes into air filter housing,goes towards the slam/landing panel.
The tube splits / rattles and can be very noisy at idle
The only other noise is a light intermittent rattle / tapping that sounds like it’s from the bellhousing / gearbox area
This is the DMF and normal,some need a plastic cover fitting up back of engine to quieten it slightly,but it’s not really a fault,and even replacing DMF will NOT cure it.
Frag
Ford Technician
Postby cricky22@hotmail.com » Mon Jun 29, 2026 9:43 pm
Thanks Frag, The little noise at idle sounds in around the front end, I've removed the Aux belt and noise remains. By applying 50 rpm its clear. Noise only at idle... It had a timing belt and water pump done and FAI cam mod done and I'm just concerned if it in that area. Some one told me its normal but i couldn't listen too it at idle. i was thinking of increasing the idle by 50 rpm to remove it but i may just be masking an potential issue but the van drives like new and only 50k,
Postby metalworker0 » Mon Jun 29, 2026 9:56 pm
Sounds very like a heat shield to me .. these things resonate at certain frequencies, they have a habit of corroding around the fixings that hold them on .. then they begin to vibrate with the engine often at certain revs.
Another thing that happens with them , sometimes you cant tell where the sound is coming from .. ones to the rear may sound like coming from the front.
here's where they are on your connect
http://www.catcar.info/ford/?lang=en&l= ... OCsxMzM%3D
Postby cricky22@hotmail.com » Mon Jun 29, 2026 10:02 pm
Let me know if yous can watch the video ok and here thew noise in question
Postby metalworker0 » Mon Jun 29, 2026 10:45 pm
it sounds like a power steering pump .. but looking at catcar.info .. it does not have one
so it may be a jockey wheel tensioner on the aux belt or cam belt
Postby metalworker0 » Mon Jun 29, 2026 11:03 pm
if cambelt - one of these two mid way up the belt diagram
http://www.catcar.info/ford/?lang=en&l= ... EzMw%3D%3D
deleted the links to aux belt because you've already tested for that
NOTE:
cant be 100 percent certain, as this is remote diagnoses, a mech would have a large screw driver to his ear and be placing it .. maybe dangerously (for you) on or near spinning parts
Postby cricky22@hotmail.com » Mon Jun 29, 2026 11:30 pm
Tried the screw driver test Mark, i am a technician but not on vehicles, but this is a strange noise i cant Pin point, Was reading something about the Idle air control valve maybe related.
Postby metalworker0 » Tue Jun 30, 2026 12:02 am
Idle air control valve - that's a petrol vehicle item
Postby cricky22@hotmail.com » Tue Jun 30, 2026 10:41 am
That rules that out.. Thanks Mark. you know anyone else that maybe heard that noise. I'm think of increasing the RPM by 50rpm to remove it. maybe just masking it but someone says its normal for those engines.
Postby metalworker0 » Tue Jun 30, 2026 2:19 pm
as far as the sound goes
well i can tell you i hear the same exact sound coming from mine and that sound is the power steering pump... and yours does not have one
so very hard to make a diagnoses .. if everything is telling me it sounds the same as an ancient 1.8 ... only i can only hear it with my head above it in the engine compartment .. cant hear it with the bonnet closed or from within the vehicle.
the sound i'm hearing in mine is normal though .. and may or may not be as loud
