Mk2 4sp to overdrive probs..How can i get it sorted?
Postby Nel5on » Thu Apr 07, 2005 7:08 pm
Ive got a mk2 motorhome and its a bit slow...wanted to cruize at about 65-70mph but its likes 60 and i have to find a slow truck to sit behide rather than passing them.
Problem is my 4spd is a spline driveshaft input into the gearbox and the overdrive box i just got is a flange(only discovered this once i got home)....whats the best way to get around this problem? Do i have to cut and weld the driveshafts(can they be rigid?)...I just dont know with transits...i know Anglias,escorts,cortinas...Just wanted a cheap way to go faster and get better MPG.
Any thoughts would be great.
Nelson...The Kiwi[color=blue]
[/color]
Nel5on
Postby transitgeoff » Thu Apr 07, 2005 10:23 pm
take the train :lol:
transitgeoff
Postby sixwheelphil » Thu Apr 07, 2005 10:38 pm
Nelson, yep, it's gotta be cut and have a slider put in and a flange on the end. If this is any help, over the Christmas holiday I changed to overdrive in my MK2, so had to have a prop done. I got it done by Chassis Developments at Leighton Buzzard. They got a new slider and new flange, and done the job for £168 and some odd pence. They had it ready the day after it went in to them.
The man to speak to is Ron Smith, he's the propshaft man, on 01525 374151.
sixwheelphil
Customised!!
Postby madmark » Fri Apr 08, 2005 2:52 am
mate this is the problem with the overdrives poeple selll them without the prop and also the crossmember ,the prop as phill say will have to be changed for the corect end ,also have you got the crossmember that holds the overdrive box it is completely difrent ??????????? are you running a pinto? if you are lucky the bellhouseing will swap over if you have a g type 4 speed! ,i think you had the box form a 3ltr off of ebay didnt you??????
Postby FredTransit » Fri Apr 08, 2005 8:19 am
sixwheelphil wrote:Nelson, yep, it's gotta be cut and have a slider put in and a flange on the end. If this is any help, over the Christmas holiday I changed to overdrive in my MK2, so had to have a prop done. I got it done by Chassis Developments at Leighton Buzzard. They got a new slider and new flange, and done the job for £168 and some odd pence. They had it ready the day after it went in to them.
That's who built our Big 'Un, 19 years ago, so they must be good!!! The budget option on this conversion is to split the prop at the fron UJ, but it depends on the legth of the finished prop when fitted. We have used Propshaft Services in I think Hayes, but I don't think that's very near you.
PS, -
transitgeoff wrote:take the train
I'll remember that when I hav 122 boxes to take from London to Liecester, should save me loads of diesel! :wink: Wanna come and give me a hand? :lol:
FredTransit
Mk2 Trannyist
Postby transitgeoff » Fri Apr 08, 2005 7:51 pm
Yes Fred, i will give you a hand to get that MK1 from your yard :D i will bring my hiab lorry if it will help :wink:
transitgeoff
Postby FredTransit » Sat Apr 09, 2005 12:20 pm
transitgeoff wrote:Yes Fred, i will give you a hand to get that MK1 from your yard :D i will bring my hiab lorry if it will help :wink:
.................Ha ha ha, I meant the with the load. And a hiab will do the van loads of good if you want to restore it, no? :roll:
FredTransit
Mk2 Trannyist
