MAF and smoking.
MAF and smoking.
Postby seanlitar » Sun Jul 12, 2026 5:01 pm
What is the correct MAF reading at idle for a transit 2.2 2016.
I have 2 vans. one reads 9g/s and the other 13g/s.
I fitted recon engine, new throttle valve and turbo, recon fuel valves and the van is smoking when reving at standstill, and accelerating.This van reads 13g/s and I am wondering if being overfueled. The van has DPF delete and EGR blanked,
. Recent map to original. Just think its running rich at low RPM. If MAF is false high will it overfuel?
Any ideas thanks.
seanlitar
Re: MAF and smoking.
Postby Airthies » Sun Jul 12, 2026 8:32 pm
Swap the sensor and check if the values change between vans.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby seanlitar » Mon Jul 13, 2026 5:54 am
Airthies wrote:Swap the sensor and check if the values change between vans.
I tried that so its not the sensors. Each van reading is the same.
seanlitar
Postby Airthies » Mon Jul 13, 2026 6:37 am
Checked your turbos? Turbine bearing slop, vane free movement and actuator operation?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby seanlitar » Tue Jul 14, 2026 7:14 am
Its a new TC, recon engine and injectors. New throttle valve.
seanlitar
